Dear all,
I am looking for a mathematical formula for the energy needed to push a caster over a curb.
My reasoning and my assumptions so far:
1.) Standard rear drive wheelchair approaching the curb in a straight line (both casters touch the curb at the same time)
2.) flat surface and a 90° curb
3.) The tire traction is sufficient to convert all motor torgue into movement
4.) Max controller limit = max torgue
5.) The curb is smaller than the radius of the caster wheel (curb hight < radius of the caster). This also means that if curb hight > radius of the caster it becomes impossible to surmount the curb. In the special case of curb hight = radius of the caster the energy requirement should infinite thus for all practical purposes it becomes impossible to surmount the curb.
6.) No friction or other losses
I started out to apply "Inelastic collision" formulas because I frequently hit curbs at speed (as a kind of run up) but to no avail.
Now I am starting to think that as at the time of impact with the curb the speed can be close to zero, it may be better to think of the movement as a straight lift. Meaning that I just have to calculate the energy needed to lift the mass of the casters including all the mass resting on the casters by the hight of the curb. Basicly asking: "How much energy is needed to lift a mass of 50kg by 5 cm?"
Am I on the right track?
