Programming leads
Re: Programming leads
Postby Burgerman » 14 May 2025, 19:39
Unfortunately the man who knew everything about these cables has left for good. RIP.
So you will need to read a few forum posts and order a cable and adapt it to suit.
Postby jamess » 15 May 2025, 22:41
Thank you for your response, and unfortunate to have lost this man. Since I am very new to this and my wheelchair is new as well, could you help me in any way to determine what cable needs to be ordered please? It seems like there is a a control board that needs to be built in line with the cable but I could be wrong. Also, if someone already has a cable that I could buy or rent please respond.
James
jamess
Postby Burgerman » 16 May 2025, 00:18
These are correct I think. You just add a resistor and a low drop type diode. Diagrams are on the board somewhere! And a connector.
https://www.amazon.co.uk/Serial-Adapter ... sccl_1_3_i
Postby jamess » 18 May 2025, 15:35
After reading a lot of posts, it seems that the sdrive controller in my unit is a s140 which requires a different cable setup?
Can anyone confirm that the original cable with only a diode and resistor can work on a sdrive s140 controller? If not, I dont think I have the skills necessary to build the cable as shown in the link above. Im more than happy to pay someone with that level of expertise.
Thanks all.
jamess
Postby rover220 » 18 May 2025, 17:27
i have probably got genuine cables to save you having to make one if you would prefer
Postby jamess » 18 May 2025, 20:28
yes please let me know how much you will charge for this? thank you
jamess
Postby rover220 » 18 May 2025, 21:15
jamess wrote:yes please let me know how much you will charge for this? thank you
Will check what I've got tomorrow
Postby jamess » 25 May 2025, 03:57
Hello, checking to see if you had a chance to look in your inventory for a pg drive s drive programming cable. Happy Memorial Day weekend to all!
jamess
Postby rover220 » 25 May 2025, 06:14
jamess wrote:Hello, checking to see if you had a chance to look in your inventory for a pg drive s drive programming cable. Happy Memorial Day weekend to all!
Sent you a pm last week
Postby dieseldog » 26 May 2025, 19:50
Pmd you to rover220
dieseldog
Postby jamess » 28 May 2025, 22:50
I sent you a return message rover220. Sorry, computer use isnt my strong area and also pretty new to this message board.
jamess
Postby Diesalweasel » 05 Nov 2025, 22:02
[quote="rover220"] ive sent you a pm regarding cable
Diesalweasel
Users browsing this forum: No registered users and 32 guests
