Burgerman wrote:They might fit, but are too high impedance, judging y that 22A inrush current limit.
It's a pity they don't fit, because MK batteries used to be available in Moldova, but they're no longer sold. I'm now looking for other options. I'm also considering using LiFePO4.
Burgerman wrote:Well if you look at those they must be able to do 200A current as thats what the 120A X2 controller on the chair can pull from a batery. Max. Depending on programming. And lithim do not like anything in extremes. And so they like to be not full, not empty, no heavy
Ideally you wn to look at double the Ah of lead to achieve that. But you cant do that with drop in lead brick replacements.
When looking at lead batteries look for cycle life (500 @ 80% DoD) and IMPEDANCE of 5 or less. Dont worry about Ah so much.It's a pity they don't fit, because MK batteries used to be available in Moldova, but they're no longer sold. I'm now looking for other options. I'm also considering using LiFePO4.
What about eBay and the pretty good 80Ah gel Haze batts?
https://www.ebay.co.uk/itm/130633616407
fordragon88 wrote:I'm also considering using LiFePO4.
Burgerman wrote:I might be tempted to move elsewhere before putin decides that he wants to continue his obsession. He wants to get the band back together, and you are likely next.
Is there a proper spec sheet for those batteries you linked to?
They could be OK. But no way to really know.
rover220 wrote:For special controls an omni would be best but you can use rnet connected versions of the movis micro or multi joysticks.I can supply if required.
shirley_hkg wrote:fordragon88 wrote:I'm also considering using LiFePO4.
That's too easy to decide. Forget VRLA.
LiFePO4 is cheaper than lead-acid now. At half of its price, you will get a set of lithium that outlasts your chair, or your life, plus 5X of range … too much to mention.
martin007 wrote:Welcome fordragon88!![]()
And has the grape harvest started in Moldova?
martin007 wrote:Are you closer to Chisinau or to Transnistria?
fordragon88 wrote:Burgerman wrote:I might be tempted to move elsewhere before putin decides that he wants to continue his obsession. He wants to get the band back together, and you are likely next.
I would gladly leave here, but I just have nowhere to go. I have a house here, it is equipped so that I can easily leave in a wheelchair.
I could only find a link to their manufacturer's website, but the specifications listed there mean nothing to me.
https://csbattery.cn/products/hdc12-75- ... n-battery/
martin007 wrote:No politics.
The question was about physical and social proximity.
Language, etc.
"Politics for politicians"
shirley_hkg wrote:https://www.wheelchairdriver.com/board/viewtopic.php?f=2&t=12287
Burgerman wrote:If this battery assembler has any clue at all about what he is doing then how to fit a 24V battery to anything is OBVIOUS and simple. The fact that he says he doesent know how tells you all you need to know about him. Run away.
Theres 2 batteries connected in series. Like every 24V system in existence.
The only thing different to the drawing is that theres a simple breaker or fuse in that link between the two batts.
I suggest that you find someone else that is competant. Or DIY.
Burgerman wrote:That PL8 charger is a 1340 watt charger. Or a 3 watt charger, from 1 cell, a watch battery or a AAA cell, to a 230Ah 24V chair pack, 5 different chemistries and a discharge capacity tester all at once!
It needs a 10 to 28V power supply. It can step UP voltage so that you can charge a 24V chair in a car... From 12V system. Or one chair from another at 40A if you need to. Or in my case my RC helis, from my chair at the flying site... So LiFe chair to LiPo 6S 25.6V for the helis. Flexibility is the key.
To power in in my home I use either a 30A 24V bench power supply, like in the previous pics, or a ZXD from shirley....
A picture of that is below... I have 2.
YOU dont have to do things the same way...
That can do 0 - 70V. 0-50A, 2 or 3 stage PROPER charging for lead, OR lithium with a BMS or just function as a power supply for testing or powering things like the PL8.
Its 3000 watt capable... So can charge a chair with large lithium as fast as your house can provide. Does your head hurt yet?
Users browsing this forum: Seafighter, shirley_hkg, tettralytic and 715 guests
