Dan wrote:If the batteries are only lasting three hours around the house you probably have a battery problem. That might dependent on your weight and your wheelchair's plus the type of flooring in your house. Outside on rough terrain at 8MPH or a lot of turning or stopping and starting can murder batteries.
What is the capacity of the batteries and has it been checked? How old are they and have they been looked after? is your charger changing the batteries properly? It can take eight hours plus to charge a battery to 100% though it will get to 90% charged before that.
I would say that your batteries are toast. Does your chair freewheel ok? Your motors being the problem is low on the list of probabilities.
Recently, my OG permobil sla/agm batteries are only lasting like 3 hours from a "full charge" (lol).
I will be putting in a lifepo4 pack soon but I remember last time I had such terrrible battery issues, it was the motors draining it and the wheelchair dealer checked the motors instead.
My question is, what did they check in the motors, just the resistance? How do I check them? What should the values be?
Burgerman wrote:What battery. What have you been charging with?
How old?
Knowledge is power. I used to eat a set every 9 months. The NHS said they would stop replacing them so I did what I should have done from the start. And looked after them properly. Now they lasted 4 to 5 years. Then I went lithium.
If using those "permobil" branded batts and their charger you ill likely cook the batteries fast. DETAILS and technique matter.
Superchunk wrote:Burgerman wrote:What battery. What have you been charging with?
How old?
Had a really weird experience today. All stock permobil batteries and charger. My batteries have been getting worse and worse, dying every 20-60 mins, so I was charging multiple times a day. Last night when I was charging, massive burning smell coming from somewhere in the chair and the charger was flashing. Since then, the battery has lasted me all day without needing to charge. What is going on here? what was burning? why are the batteries ok now? Thought it was the XLR port on the rnet joystick that was burning, but looks fine to me, no? I put some WD40 in it to clean and charged for an hour, no burning smell, no heat.
Burgerman wrote:Superchunk wrote:Burgerman wrote:What battery. What have you been charging with?
How old?
But we still do not know any of the above that I asked. Is this permobil BRANDED battery? Is it a permobil "special" branded charger tat they claim is needed? Because if boh these things are true they have 2 problems.
martin007 wrote:1- Are they Gel batteries?
2-Is the charger for AGM batteries?
Only chargers fitted with Neutrik NC3MX plugs should be connected into the Joystick Module.
CAUTION:
The maximum permissible charging current for both methods is 12A rms.
WARNING:
Do not exceed the maximum charging current of 12A rms. Always use an Off-Board Charger fitted with a Neutrik NC3MX
plug. Failure to observe these conditions could result in poor contact resistance in the charger connector resulting in
overheating of the charger plugs. This presents a potential burn hazard for the user. Curtiss-Wright accepts no liability for
losses of any kind arising from failure to comply with this condition.
Burgerman wrote:1. The fancy permobil rebranded charger does not have a genuine connector and used a cheap generic branded one. That was not very good quality and it added a resistance that cause the contacts to get hot. That in turn oxidised them. Causing ever more resistance and bad charging and ever more heat. In many cases it actually melted the joystick connector too. Permobil was forced to recall and replace many joysticks, and replace the chargers.
Burgerman wrote:2. The algorythm on those chargers charges at too high voltage and the batteries dry out, go high resistance and in many cases swell up and die a very early death too.
martin007 wrote:Are you saying that the caps on your battery cells have opened as a result of charging...?
Burgerman wrote:martin007 wrote:Are you saying that the caps on your battery cells have opened as a result of charging...?
He is saying the caps that shouldnt ever come out were popped due to too high pressure caused by gassing, caused by a stupid CV voltage setting in the charger that murders the gel battery... Yes.
Users browsing this forum: Bing [Bot], emilevirus, jefferso, slomobile and 364 guests
