6. The rosin and lead from the solder is toxic, I would STRONGLY advise dunking in a container that is preferably dedicated to non-food use, and definitely liquid that you won't be drinking...
Theres not enough metal in those connectors though for any kind of crimp to hold well without soldering too. Once heated, and solder is ebsorbed, they are seriously strong.
I am thinking about trying out a small torch rather then the weller gun I now use as I think it might be a bit easier to handle for me.
Fulliautomatix wrote:I had a big ugly join of 3 x 8Ga + 1 x 18?Ga so I can distribute 24V - to PM, charge and accessories.
Best I could manage was to lay the 8Ga together and bind with 18Ga, hit it with an 80W iron and pour in the solder, then a couple of layers of heat shrink.
Burgerman wrote:I am thinking about trying out a small torch rather then the weller gun I now use as I think it might be a bit easier to handle for me.
Trust me, its much faster, solder runs better because less flux gets burned and less time for oxydation, insulation stays cool because of the speed. You will never use a soldering iron on anything but small stuff/circuit boards again. Far more controllable.
Dont tell me you dont use flux! On small new clean connectors/wires you can get away with the cored solder alone.
Burgerman wrote:There are lots. Many are acidic and agressive so as to clean oxides on even dirty copper/brass. But it causes corrosion afterwards.
You just need http://www.rapidonline.com/Tools-Equipm ... elly-61559 or similar.
Seajays wrote:It says " On June 26, 2010 the Canadian Department of the Environment elected not to ban five rosin-containing substances from all products manufactured and sold in Canada."
Users browsing this forum: No registered users and 143 guests
