GREAT JOB! (But don't expect Mr. Smith to understand it.)
Tony, mobility-specific chargers are engineered to meet the charging voltage of mobility-specific batteries.
The CTE charger (and those like it), is designed to charge both AGM and Gel batteries by delivering a voltage within the correct range (and, per battery manufacturers, there is a tolerance to charging, not an exact number). Here's an example:
MK 22 Gel pair (cycle) = charge between 27.6v – 29.2v
MK 22 AGM pair (cycle) = charge between 28.8v – 29.16v
The CTE charger delivers 28.8v in its “constant current, bulk stage,” then drops to 27V once 80% capacity is reached, charging the batteries to completion, so you can see that the 28.8V rate of the charger hits both Gel and AGM lead acid batteries, and the multiple stages helps optimize both the charging cycle and battery life. For the consumer, he or she should rest assured that mobility-specific batteries and chargers are engineered to offer optimal performance in working together. Thank you.
Sources:
http://mkbattery.com/images/M22NF%20SLD%20G.pdf
http://mkbattery.com/images/M22NF%20SLD%20A.pdf
MK Charger Reference: http://mkbattery.com/images/charger0603.pdf
Woody states conjecture: Mobility chargers may be reducing battery life by 30%.
Ex-Gooser immediately then restates it as a fact: Mobility chargers are reducing battery life by 30%.
Then, SweetBearCub reads Woody's conjecture, turned into fact by Ex-Gooser, and is now alarmed by the problem (which was literally fabricated from fallacies of logic).
What we have, therefore, is not a technical discussion, but a tabloid discussion, with no credibility, based in fallacy, not fact.
Marvelous .. my "conjecture" is being read!!The views on these threads skyrocket, so keeping them going actually increases the readership.
They're not just reading YOU ...JEEZ !!!Ignoring me is far more detrimental to me because if I have no readership
Users browsing this forum: Burgerman, emilevirus, shirley_hkg, snaker, Yennek, yeshelp and 124 guests
