zamahuikano wrote:Hi and thanks, I've tried assigning ports COM1, 2 or 3 and none of them I can communicate. I can see the port assigned in the device manager and when I open is also 1314. As I have tried several USB/Serial as Belkin, PL2303 chip and one with CH340, I always get "code39" I see with the Putty or spyglass 840, but not communicate with the 1314 "Error 0023". One of my questions is whether it is necessary to have everything connected to program and/or communicate. I say this because I have the controller working in the bank provisionally and truth circuits seeing so many different ways and many people talking about their problems, I'm lost.
As I say the Com drivers is installed without any errors.'ve tried on several COM "1.2, y3".
Yes ..BUT .. ( to the best of my knowledge ) it will not work to test the CANBUS transmit and receive.Woody: That program you use to check your cables with, will it work with Windows Vista?
LROBBINS wrote:This is probably a stupid question. Was your WC controller turned on when you tried to connect? Ciao, Lenny
Users browsing this forum: acid_coke, Bing [Bot], jefferso, jehan and 439 guests
