JoeC wrote:As I started to leave the corner to cross a busy street I was limited to a top speed of 1mph.
Burgerman wrote: Or the New MK 3 one will do 8.5 mph with a pair (24v) of odyssey batteries. You dont have to go to 12.75 mph. The same batteries fit, 3x 1200 or 2x 1500.
JoeC wrote:I would probably still use the DX2 for a chair I build from scratch. The fail-safe design has been beaten to death and passed ridiculous levels of scrutiny. I know how to program it to have a very favorable character. It's capable of tweaking the battery gauge to function passably with a lithium chemistry that doesn't require a charge voltage higher than the lockout level- and I believe the Valence batteries are such a chemistry. Power seating and auxiliary devices can plug into the system seamlessly, and can take whatever switches I like. For my wife's needs, I think DX2 is great for everyday use- only for sports would Roboteq be a stronger contender. Before I get into these projects we will have to see what 2012 brings.
Burgerman wrote:Both NK2 and MK3 chairs can take (and will take) either 2 group 24 batteries, or two Odyssey PC1500 batteries, OR 3 Odyssey PC1200 and run 36v -- Controller allowing. But I may retrofit all my chairs with the Roboteq as its much more powerful - at least with Odyssey rather than Gel batteries.
Reading between the lines Joe, did you get the impression that they maybe thinking of a DX with more volts/amps?
Burgerman wrote:>> I meant a pair of 2150 Odysseys.
Ah, well that was a possibility, but I went with 36v and three 42Ah batteries instead! I prefer speed. The roboteq allows that and this increases efficiency a little too.
Burgerman wrote:Agreed. Unless you consider the 50v advantage. That makes it twice as powerful at the same Amps. And its more. It only matters though if you are looking for getting speed out of the system as well as torque. But your wife is light. But you miss out on the challenge of figuring it all out!
Users browsing this forum: No registered users and 19 guests
