and the Wine - thats just a very good bottle
but the first picture is the way mines are in the tray - 13 inches long way
yes i may be - but then again - i wasnt able to fit the PC1500 in there -
Scollard wrote:OK expresso. So each battery is 10" x 8" x 6.75".
A 6x6 cell battery pack made with the 12AH Headway cells measures 9.5" x 9.5" x 6.85" (240mm x 240mm x 174mm). This is nominally smaller than a group 24 sized battery. If you measure your box, it should be possible to put 2 of these packs into the battery box.
maybe thats throwing it off - -
BounderGimp wrote:Scollard wrote:OK expresso. So each battery is 10" x 8" x 6.75".
A 6x6 cell pack would give a nominal voltage of approx 19.something? Did you mean to say an 8x6 pack, it would be a bit over 25v. OK, what did I not see?
Burgerman wrote:There comes a point where you have to give up re-explaining the same thing over and over.
expresso wrote:just curious - how many users have done a full chair ? maybe would be nice to hear from them - to explain any issues they ran into or not - which model chairs - so others with the same chairs etc, have heads up on whats ahead for them
expresso wrote:my battery tray is 334 mm Long x 259 mm Wide - x 235 - 240 mm High - that fits two batteries perfect - very tight on the top by the posts -
Now it looks like it would fit - if you compare to your 240mm x 240mm x174 -
but the inches dosnt seem like it -
would this be in the same postion once built - or on the side - thats whats confusing me also - BM has it built and turns it on the side - so the orange blocks are on the side - i am looking to have the blocks on the top and bottom - maybe thats throwing it off - -
in the end - only way to know is to try it - with 36 cells - connect them and see if its correct - or just buy the blocks with 4 cells and i can see with my eyes then -
i have a thing for visuals - when i see something - i can then make more sense of it - most times -
steves1977uk wrote:expresso wrote:just curious - how many users have done a full chair ? maybe would be nice to hear from them - to explain any issues they ran into or not - which model chairs - so others with the same chairs etc, have heads up on whats ahead for them
I have for one, with help from an ex-RAF engineer to build a 8s 5p 75Ah pack using the 40152S Headway cells. My conversion was fairly straight forward since I don't need tilt or lift, and the lead batteries were side by side in one box. I use a PL8 charger with a COOLICE PSU, and its not that hard to set up and configure. Been using a lithium battery pack for over a year now without any issues.
Scollard wrote:expresso wrote:my battery tray is 334 mm Long x 259 mm Wide - x 235 - 240 mm High - that fits two batteries perfect - very tight on the top by the posts -
Maybe you should go to Home Depot, get some styrofoam, and make two cubes 240 x 240 x 174mm to simulate the size of the battery packs and test fit these. That should put you mind at ease.
Burgerman wrote:Assumption. Or presumption. I do it too. It usually means:
The mother of all f*****s...
Users browsing this forum: fordragon88 and 239 guests
