steves1977uk wrote:expresso wrote:just curious - how many users have done a full chair ? maybe would be nice to hear from them - to explain any issues they ran into or not - which model chairs - so others with the same chairs etc, have heads up on whats ahead for them
I have for one, with help from an ex-RAF engineer to build a 8s 5p 75Ah pack using the 40152S Headway cells. My conversion was fairly straight forward since I don't need tilt or lift, and the lead batteries were side by side in one box. I use a PL8 charger with a COOLICE PSU, and its not that hard to set up and configure. Been using a lithium battery pack for over a year now without any issues.
Burgerman wrote:Theres a point where you realise that no amount of typing will help. That point was pages back! I will regret this but here goes again...
This is my final attempt at explaing the same thing in yet another different way. I have run out of ways to do it now!
You can get 36 cells inside the size/shape of a group 24 that is 240mm tall. And you HAVE 240mm height? And you already have group 24 batts... Think about it. That set of group 24 batteries fit dont they?
Burgerman wrote:At great risk of repeating myself for the hundredth time, 6x6 = 36 cells.
9 in parallel, x 4 in series = 12V nominal. (9x 12Ah = 108Ah). Gives one block.
Two Are required for 24V. It will fit any chair that takes a group 24 battery in its specs because a group 24 is specified as 260L, 173W, 225 high. ...
Burgerman wrote:They will all have been fully charged at any time from a few days to a few months ago.
PL8? To charge 1 cell or a group of cells in parallel, you need to either cheat (using a lead preset -- ask if you want to know) or use a preset designed for A123 batteries, with a 1S balance lead made up, so you will need a connection to the balance ports as well. Or check out the LiFe preset that just arrived. Not sure if that works, untested as Its new - but looks like it will do 1 cell without balance lead. Could be wrong![/i]
disappointed - i feel i should have ordered more cells to start with
expresso wrote:I agree - going to school when i did go - i didnt learn much -
when i got a job doing the work - i learned more -
i will get my utilty cart in a few days - at least i have a place to put all these new tools i have to get wires etc, - in one place - and roll it around as i need it
i forgot to add the rubber hammer to tap the blocks in place - on my next order -
http://www.hobbyking.com/hobbyking/stor ... 0amp_.html i think i like this unit - i really hate units with no power switch on them
i like to switch it on when i want - and off as i need with out unplugging all the time -
this PSU with the Cellpro 8 - would be good even for MK GEL and AGM etc, - if in 24V connected - but single battery 12V - it cant do ? or can do that also
flagman1776 wrote:I plugged my power supply into a dedicated switched power strip... just throw the switch & my 1420i powers up... after connecting to my pack of course.
shirley_hkg wrote: That 50a power supply worth $25 here. Rip off price.
expresso wrote:shirley_hkg wrote: That 50a power supply worth $25 here. Rip off price.
so i guess thats not the one to get then - off the list of PSU - -
