expresso wrote:very good - you know much more than me and i live here in NYCi never bothered to look -
Shirley those are good prices if you ask me - if you really do decide to visit here - and you find a place - if its close to me - i can go take a ride there to check it out for you also -
Burgerman wrote:Carpets?
Irving wrote:Burgerman wrote:Carpets?
Yep, all hotel rooms I've been in have carpets, except one serviced apartment.
Burgerman wrote:What exactly are you charging?
You have a preset set up for 1S but single cell. Or 2 max. In parallel.
You have one set up for ADD ON pack with cell balance 8S.
You have one set up for 150Ah that needs cell balance wires for 8S.
If you need to charge 150Ah all connected in parallel you need to set the 1S pre-set changed to say 30A charge. Because that one will not ask for a balance cable... And termination changed to either: Manual setting 900mA or to C/20 Auto. With a 1 or 2 hour max CV time limit.
Burgerman wrote:Yes I remember now. Long slow initial soak to bring all to 100%. But it will take a long while.
Once all are balanced and done a couple of charges theres no need to go to 200mA. Charge can end when balanced and a bit less than an Amp if you want. Its best to do a complete charge initially.
Different on the Hyperion which determines its own cutoff termination current.
Users browsing this forum: LROBBINS and 374 guests
