Arduino controlled wheelchair
Re: Arduino controlled wheelchair
Postby gcebiker » 11 Apr 2016, 12:41
Oh,
data[1] = (speed >> 3) & 0x7f;
data[2] = (direction >> 3) & 0x7f;
data[3] = (speedpot >> 1) & 0x7f;
not sure of the BitShifting Irving, but now i finally understand the "& 0x7f" ...that gets me the 7MSB per the documentation....i feel so stupid now :?
Speed and direction are 10bit readings....so the BitShifting is to convert them to an 8bit number same as the maxSpeed pot ?
and you are shifting three places instead of 2...because ...na Ive no idea about that one.
..oh and sorry about the mass posts today, Ive hit my stims up to wake my brain up so i can think and i kind of have to 'hit the books' as it were while i can before darkness on my mind falls and i am 'out to sea' again.
gcebiker
Postby gcebiker » 11 Apr 2016, 13:38
Hoping Jim is feeling Generous, i have just emailed him and begged for a bit of correction.
Its my feeling that code in other parts of my sketch may be mucking things up, and as Jim has already done this successfully with a RoboBoard in Python ...he probably has a pretty good handle on where i went wrong.
After the dog came three weeks ago and me clipping her heels with my chair as i turned around i have been trying to walk around the house...and that's not been working out so well...i really need to get sensors on my chair...or get better at walking :)
gcebiker
Postby Burgerman » 11 Apr 2016, 17:13
Or a faster dog. :lol:
My german sheherd dog met my chair a few times as a puppy. He soon figured out that the wheels hurt. After that he never once got under a wheel or caster. They learn very fast. He was inch perfect on walks etc or indoors. You couldnt run over his feet if you tried. Sadly RIP now.
Postby gcebiker » 12 Apr 2016, 13:19
In reading Jim's notes, i see him declare 'unsigned char'....i first used 'int' then yesterday 'unsigned int'
I will try changing it to 'unsigned char'
This is the Python code that worked, i am not sure how to translate it to C++ for Arduino, though it shares a fair amount of similarities.
I am interested in the " & 127 " v's 0x7F .. and there is more, this little bit of code for sure is a lot more complicated than it looks.
Decoding it ...is not my end game, i just dont want to run over my puppy...
Today i purchased an RC 'Esky' Trolley... it was already remote controlled, came with a battery and looks pretty sweet...12v geared reduction motors with Golf Cart wheels, Free Wheeling hubs...Steel frame and a check plate Alloy top to put your Esky on.......for ......yes $60 AUD ! :o
People say you cant put a $ value on some things...but mobility you can...and often its in the "shit loads of money" price bracket....but look sideways...this ESKY RC thing i bought is not marketed at the Disabled...and the prices are very affordable....
Still...i want sensors on my chair, i want senors on my blind friends chair (to be fair only partially blind), and i want flexibility with a platform that is just so capable....
I wish more of the community were contributing to this cause, its got great potential, unlock the Power Drive modules...and you unlock your feet...
I hope you can all contribute if only with your dreams of unlocked mobility.
Code: Select all
void sendmessage (unsigned char msgtype, unsigned char outbuf[32], unsigned char length)
   int n, wres;
   unsigned char firstbyte, parity=0, sendbuf[32]="";
   firstbyte=msgtype+((length-1)<<4);
   sendbuf[0]=firstbyte;
   //printf("FB: %x\n", firstbyte);
   parity=firstbyte&127;
   for(n=0; n < length; n++) {
      parity+=(outbuf[n]&127);
      sendbuf[n+1]=outbuf[n];
      //printf("%x ", outbuf[n]);
   parity = (255-(parity & 127));
   //parity = 0xe4;
   sendbuf[n+1]=parity;
   sendbuf[n+2]=0x0f;
   //for(n=0; n < length+3; n++)
   //   printf("%2.2x ", sendbuf[n]);
   //printf("\n");
   wres=write(sharkfd, &sendbuf, length+3);
   //printf("Write result: %i\n", wres);
gcebiker
Postby Irving » 12 Apr 2016, 19:40
Going about understanding the above differently....
(speedpot & 0x1) = (255 & 0x1) = (1111 1111 & 0000 0001) = 0000 0001 and then shifts it 6 places...giving 0100 0000
(speed & 0x7) = (190 & 0000 0111) = (1011 1110 & 0000 0111) = 0000 0110 and shifts it 3 places ...giving 0011 0000
(direction &0x7) = (191 & 0000 0111) = (1011 1111 & 0000 0111) = 0000 0111) and no bitshift = 0000 0111
Bitwise OR is " | " sign, meaning if any of the numbers being summed are 1 then the bit for that position is 1 ?
0100 0000
0011 0000
0000 0111
=0111 0111 = 119 ?
I used the Dec values i see in the trace from the factory joy read...and the factory result is 214...so i am getting closer i feel, to understanding it, definitely getting smaller headaches thinking about it :)
NO you made a fundamental error above... the decimal values in the trace are already coded. 190 and 191 are only part of the decimal value, already shifted right.
reviewing the data values from the lower trace in post 81554 above
you have data[1]-[4] = {0xbe, 0xbf, 0xff, 0xd6}. removing MSB this translates to {0x2e, 0x2f, 0x7f, 0x56} which in turn decodes to:
maxSpeed = (0x56>>6) | (0x7f << 1) = 0xff = 255
speed = ((0x56>>3) & 0x7) | (0x2f<<3) = 0x17A = 378
direction = (0x56 & 0x7) | (0x2e<<3) = 0x176 = 374
These the values you need to be inputting for speed and direction. if not, then its no surprise the outputs don't tally.
'& 127' is the same as '& 0x7f', the former is decimal, the latter hex. Tho identical, the latter is better syntactically as we are dealing with bitwise and/or functions.
As far as I can see there is no issue with 'direction/numbering' of bits. They follow standard convention of bit 0 = LSB of byte. The only confusion is the way the logic analyser shows the data stream LSB to the left which is correct as regards time sequence (time progresses right) but is counter-intuitive to the way bytes are normally written and the reverse of the hex value of the byte in blue above it.
There is however one glaring error in the code I wrote. Remember way back the issue of framing. The first/start byte has its MSB set to 0 to denote start of packet, subsequent bytes of the message have MSB set to 1. So the following corrects that:
Code: Select all
    maxSpeed = 255;     // this is a fixed value ...being full speed on the Shark Remote
    data[0] = (0x60);    // Packet type identifier
    // Assign joystick and speedpot MSBs values to data[1 ] - data[3], setting MSB = 1
    data[1] = 0x80 | ((speed >> 3) & 0x7f); // Joystick speed reading (7 MSbs)
    data[2] = 0x80 | ((direction >> 3) & 0x7f); // Joystick direction reading (7 MSbs)
    data[3] = 0x80 | ((maxSpeed >> 1) & 0x7f);   // Speed pot reading (7 MSbs)
    /* encode LSBs into data[4] as follows
      bit 6: Speed pot reading LSB
      bits 5-3: Joystick speed reading (3 LSBs)
      bits 2-0: Joystick direction reading (3 LSBs)
      and set MSB = 1 */
   data[4] = 0x80 | ((maxSpeed & 0x1) << 6) | ((speed & 0x7) << 3) | (direction & 0x7);
Postby gcebiker » 13 Apr 2016, 08:01
Holey Moley Batman....plugged that code in Irving and getting responses from the base !
Chair is not moving yet but base is responding, its probally not moving as the values for the joystick are not neutral like they should be, this is an error in my mapping earlier i guess but i will go thru and try to find it.
It may aslo be that i need to do the bit math for the other data bytes, instead of straight write, i am hoping not as the other values are for stuff i dont need at this time.
RS485_DG419_LM7812_UART_hardwired_data_1to4_and_checksum_bitmat.zip
updated file with bitmath for 1-4 and the checksum
(4.48 KiB) Downloaded 317 times
gcebiker
Postby gcebiker » 13 Apr 2016, 08:26
Changed from 'unsigned char' for Analog variables to 'int'
Removed mapping of analog variables,
now getting correct 'neutral' values...
chair still not moving but by god i am metaphorically jumping up and down in it.... :D
gcebiker
Postby gcebiker » 14 Apr 2016, 04:54
very minor tinkering with code and chair is now MOVING...well the gearbox is unlocked so its freewheeling but you get what i mean.
gcebiker
Postby gcebiker » 14 Apr 2016, 08:16
I am still trying to work the answer out myself...but not having any luck so far and getting a lot confused.
[/code]
Minimum encoded values for joystick are 128 (0x80)or (1000 0000) , Max 255 (0xff) or (1111 1111)
>>1 to remove the MSB ? 0100 0000/ 0111 1111
then 3 << to convert to ten bit number ? 010 0000 0000/ 011 1111 1000
no thats not making sense , using this site http://www.miniwebtool.com/bitwise-calc ... erator=AND
if i take 128, shift right one place i get 64, then left three places i get 512
if i take 255, >> 1 = 127, << 3 = 1016
If i take 190 (neutral), right shift to remove msb = 95, then left 3 i get 760
I am trying to work the max and min actual values out so that i can map the joystick values.
gcebiker
Postby gcebiker » 14 Apr 2016, 08:29
it might also be that i need to change the VRef from 5v to 2.56v (ATmega 8 specs)
...easier to map it than rewire the emulator board tho..
Or change from a Mini Thumb joystick to something with a Logarithmic response...or do both, the hall effect of the Shark Remote would have to be a LOG response for sure one would think.
gcebiker
Postby LROBBINS » 14 Apr 2016, 08:42
Doubtful. The Hall effect Apem joysticks that several of us are using are all linear response - and I don't recall seeing any log response ones in the catalogs. Controller software often has the option of applying a logorithmic (or usually more useful, exponential) curve to the linear pot output, but the pot itself is, at least in the cases I know, linear. Ciao, Lenny P.S. I did notice one thing about the Apem Hall-effect joystick that is not the case with inductive joysticks - output is velocity as well as position dependent. If you move the stick fast enough, the output overshoots then settles back to the one that corresponds to position.
Postby gcebiker » 14 Apr 2016, 08:55
Oh yeah, i guess the Shark is inductive not Hall effect.
Its not really important as i will (later tonight) just do a serial port write of the values and just watch for when it goes out of range and stops responding, remap to those values and retest till i get as close as possible.
At the movement the mini thumb stick i am using from spark fun, the max deflection at the moment is only about 45deg to get full speed.
gcebiker
Postby gcebiker » 14 Apr 2016, 10:27
After a mapping it out, i am thinking it is more to do with the cheap pots in the super cheap thumb joystick i am using.
So i will dig though and find some better joysticks or just start integrating the Wii Nunchuck wireless with the I2C or SPI (i forget which one it uses)
gcebiker
Postby gcebiker » 14 Apr 2016, 10:33
Also does not seem to like big swings in the analog readings.
gcebiker
Postby LROBBINS » 14 Apr 2016, 12:33
Are you alternating between reading the X & Y analog inputs? Be aware that the Atmega shares one ADC for all analog pins and that the AD conversion involves charging and discharging a capacitor. Hence, if there's little time between reading one analog pin and another there will be a lot of crosstalk between the two readings. You can reduce this by reading each channel at least twice and discarding the first reading - that gives the capacitor a chance to change charge level. Also, especially with the el-cheapo joystick, the analog signal will be pretty noisy, so its a good idea to average several readings before using the value. Here's a snippet of what I'm talking about:
Code: Select all
void READ_JOYSTICK_PINS (int * RawThrottle, int * RawSteering) {
  long sumRawThrottle = 0;
  long sumRawSteering = 0;
// average over 5 reads
// separately average Throttle and Steering and discard first read
// to avoid effect of delay in switching ADC channels
  analogRead(ThrottlePin);
  for (byte I = 0 ; I < 5 ; I++) {
    sumRawThrottle = sumRawThrottle + analogRead(ThrottlePin);
  analogRead(SteeringPin);
    sumRawSteering = sumRawSteering + analogRead(SteeringPin);
  *RawThrottle = sumRawThrottle/5;
  *RawThrottle = map(*RawThrottle, 0, 1023, 0, 5000); // scale to mV
  *RawSteering = sumRawSteering/5;
  *RawSteering = map(*RawSteering, 0, 1023, 0, 5000); // scale to mV
} // end of READ_JOYSTICK_PINS
Ciao,
Lenny
Postby gcebiker » 14 Apr 2016, 13:09
After doing various ADC smoothing things, double reads ,average, delays (which really muck things up due to the timing needed on the bus)
Its the pots in the thumb sticks, i can see on the Logic Analyzer the read values and its hitting max speed at only about 45deg throw.
Mapping the inputs helps but not much.
I have had the same issues with the arduino + thumb joysticks in the past.
I have had better luck with the thumb sticks in the Nintendo Wii controllers,
Ill do something like
#include wiichuck.h to work with the nunchuck.
gcebiker
Postby gcebiker » 14 Apr 2016, 13:25
For anyone following,
This is the working code such as it is.
Its a bit of a mess, its RAW, meaning you have to yourself...physically delay a few seconds before moving the sticks or it wont respond.
You also have to move the sicks very slowly or it starts to respond then stops.
Releasing the joystick to center and starting again will have it responding.
This emulator was built with the following
15v supply to LM7812
15v supply direct to DG419 chip - this provides the 'spike' at the start of the 'on sequence' that turns on the Shark Power Base.
LM7812 to Arduino Nano v3.0
Arduino Nano outputs to RS485 development board - this converts the single wire TX of the Arduino to dual wire RS485 signal to the Shark Power Module.
Input via Spark Fun thumb stick - analog input to Arduino A0/A1
Spark Fun RS232 to TTL converter has been posted and should be here early next week, i paid for express shipping...maybe it will be here tomorrow (fingers crossed) http://littlebirdelectronics.com.au/pro ... hifter-smd
With the RS232 to TTL i can check that my DWIZ emulator tests earlier in the week were correct...what does this mean ?
Your PC can talk to your Power chair, well you need a few more bits but Woody and some other rather clever folk are working on that bit.
Enjoy
SR_Emulator_mapping_attempt1.zip
(4.35 KiB) Downloaded 314 times
gcebiker
Postby gcebiker » 17 Apr 2016, 14:35
Code has been ported to Wii Nunchuck input
I think my mapping was back to front on the analog version of the code above, its fixed for this Wii Nunchuck version.
Also due to me trying to wire it up from memory...i soldered the Nunchuck Data and Clock to the digital pins (completely forgetting about the remapping in the library)
All going to plan (and when does that ever happen...hehe), in the next few days i should be able to rewire and try and get a video up of Wii (2.4ghz wireless version but could also be wired) control via my Arduino Shark Remote Emulator.
gcebiker
Postby gcebiker » 19 Apr 2016, 11:08
Did the rewire...and it all started working....but only for about 10seconds, then would reset and start getting all weird.
After much head scratching, it turns out the 15v power supply i have been using is only 500mA, not enough to power the full rig (its ok till i added the Wii)
Bought a new XLR today to see about powering it from the chair but also thinking its time for a rebuild, the proto-type board is getting a bit messy.
Also working on a ESP8266 version of the code and wiring, i am hoping the FCC certified WiFi module with its built in security might be better to use than the non secure Wii, or use a RF24 module, i am not sure - now that the code has been broken i am sure others will take it up and do all sorts of stuff.
Not yet done any more with the RS232 to ttl converter, at the moment looks like the middle pin of the XLR provides 4.7v+ and the TX/RX. I want to do more reading tho...i will probally just wire it up and see what happens :?
gcebiker
Postby woodygb » 19 Apr 2016, 11:29
I've had success with this board connecting it to a built in RS232 port and also with the same board via a MAX 3232 to a TTL - USB.
download/file.php?id=4612&mode=view
I've currently got 2 more MAX 3232 boards on order ... ( I've inadvertently killed my current MAX 3232 board :cry:) ...so that I can investigate some more .
Postby gcebiker » 19 Apr 2016, 11:34
Very cool, who makes those little beauties ?
gcebiker
Postby woodygb » 19 Apr 2016, 11:41
viewtopic.php?f=2&t=4095&start=40
I obtained the bare board from Anubis and populated it myself.
Postby gcebiker » 19 Apr 2016, 13:06
I really like his board, super straight forward for new users to wire up.
I have asked if there is two for purchase.
...i am wishing i had a 3D printer...this board is a great candidate for making into a more 'factory' look/feel.
In this day/age, its worth while for wheelchair manufacturers to start making their gear 'plug and play' .
Just like USB devices, the base units are eminently capable of performing the functions of stopping before hitting a wall...so why not let people use that functionality.
Its plain crazy mad, locking this 'usability' up.
I think its best seen in the Robotic Vacuum cleaner market where Samsung and Roomba have made their code open source.
Shit even Microsoft used the hacker community with the XBox to build the 360.
...so available to us, is the code for a robotic vacuum...and now the code for a robotic wheelchair....
the future is looking ... 'avoidable' - banging into that wall i mean.
gcebiker
Postby gcebiker » 19 Apr 2016, 13:13
It would have been nice knowing this stuff before you emailed me Woody and i wasted time and money investigating something you had already solved... I said it was TTL and you did not believe me :?: even you had already proved it to be true.
Regardless, i am happy to have been involved in avoiding the costs i incurred to do the same.
Its just a bit frustrating given the limited mental energy i have available to me, to use to put it to something that was quite unnecessary !
gcebiker
Postby woodygb » 19 Apr 2016, 13:23
Apologies if you feel that you've been taken advantage of .
Here's a direct quote from my original email.
Hi Tony,
I wondered if you have any idea of what form the comms / programming signal takes at the 3 pin charging port of the DX ?
Cheers Woody
This some how escalated into you purchasing equipment to try and find out for me ...which was appreciated .
Postby gcebiker » 19 Apr 2016, 13:38
woodygb wrote:Apologies if you feel that you've been taken advantage of .
Hi Tony,
Cheers Woody
Not advantage of, ill informed.
How could i have any idea with out having equipment to 'have an idea' .
...i am glad it was appreciated, it was also unnecessary......cost me two days of my available mental capacity and meant i had to take a day of volunteer work today.
Regardless it has borne fruit if by a twisted route, i have tonight learnt about Gerber software and the means to produce boards.
This will in turn probably bear the fruit of a DIY board a person may plug in their own sensors.
Nothing was lost other than time and the cost of building tools , it was only duplicating his hard work, and doubling up on yours as well.
gcebiker
Postby gcebiker » 19 Apr 2016, 13:43
Dead set, its been putting off my own work on the emulator - working on the RS232 to TTL,
its been worthy work ...but you had a solution and it seems that person worked a good long time to sort it out.
Respect for Anubis's work.
gcebiker
Postby woodygb » 19 Apr 2016, 14:02
Postby gcebiker » 19 Apr 2016, 14:32
Full Disclosure ...its worth a million bucks, just link the previous work when you email for a question.
Its been previously mentioned but i remind you all, .....I got SMASHED by a drunk driver... 200KM/HR + collision speed.
I am lucky i can breath on my own, my brain requires all the facts to make a decision.
I decided to buy the parts to test the QUESTION , based on the provided information.
gcebiker
Postby gcebiker » 19 Apr 2016, 17:21
Back to the point, i now know i need more than 500mA's to run the emulator.
The test emulator was getting 'brown outs' running on the 15v 500mA plug pack power supply.
I'll try to wire up an XLR to plug to power the Shark Joystick emulator.
I can then get to work on tweaking the code for it to respond properly.
gcebiker
Users browsing this forum: emilevirus, yeshelp and 64 guests
