Burgerman wrote:No anchovy? How can you not!
Burgerman wrote:120 Amps means MOTOR Amps. Not Battery Amps. Those are different. Your R-net can do 120A on each motor! 240A total!
So if your 26v lithium battery and controller feeds say 10V to your stalled motor, as you try to turn, or climb a curb, that motor can for a few seconds pull up to 120A max - limited by the r-net...
So when your motor is at 120A x the controller actively limits it to this level via its pulse-width control. It does this by lowering average motor VOLTAGE. Or in fact controlling the pulse-width. At say 10V ? (a guess) that means 120 x 10 = 1200 motor watts.
The amp draw on the BATTERY will be 1200 watts, div by 26v = 46 Amps. You have 2 motors. So it could be: 46A x 2 motors = 92 BATTERY Amps.
Has your head exploded yet? The actual figure depends on motor impedance.
LROBBINS wrote:Remember, the 100 A breaker will hold for about 16 minutes at 135 A (135% for 1000 sec). You'll be OK with that.
