Burgerman wrote:They have it after the holiday season! And everything stops.
Burgerman wrote:You 'mericans...
flagman1776 wrote:Expresso,
Can you anchor one side of the SB50 for better force in removal? Like BurgerMan did on his chair! The holes through the housng are for small mounting bolts. There's also a low force version of the SB50. I wish I'd bought it... they are just smaller bumps in the contacts, in the same housing.
The '50' in SB50 refers to AMPS rating. Can't help on the others.
Burgerman wrote:No it refers to the fact that its hot plugable at up to 50A x number of times. Actual Amp capability far higher. 120A.
Thats what I would use. The others are designed for hobby use to be as light as possible. To pass lots of amps for flight.
https://www.google.co.uk/url?sa=t&rct=j ... tw&cad=rja
Burgerman wrote:Oil filter is for my van. And a very expensive gallon of Mobil 1 full synthetic 0w-40 SAE oil. Stupid price but I used to build race engines and break them. Its the best there is. Absolute total overkill for a van! Any old 5w-20 recommended. Thats rubbish! I couyld explain why but you wouldn't want to hear it.
https://mobiloil.com/en/motor-oils/mobil-1
For that vehicle the one you want is the 0w-40 one. http://www.mobil1.co.uk/synthetic-engin ... 0w-40.aspx
shirley_hkg wrote: What's the biggest charging current of PL8 , with 12V input ?
Users browsing this forum: acid_coke, emilevirus, JazzyBand, jefferso and 438 guests
