Gnomatic wrote:expresso, what kind of dumb charger were you using to charge your add-on pack when you still had the BMS connected to it?
Gnomatic wrote:I really like this idea for a temporary travel charge setup.
Anyone have a suggestion or a link to a decent BMS for this application?
ex-Gooserider wrote:....
So this leaves me with the question of whether or not the 15Ah 4s6p pack would fit...
ex-Gooserider wrote:Thanks for the photos Gnomatic... Bad news is that it looks like I can't get away with the 96A approach after all.. As best I can make out your measurement photo, 6 cell blocks are 9 15/16" tall, = 252mm. This works out to 42mm / block, or 2mm / block less than what Evassemble gives for block size when assembled... The second picture looks to be 13.25" which works out to 42.0625mm, or about the same. So I'm right in that stacked blocks come out slightly smaller, but not enough to help...
Measuring my box with a steel engineering rule, I get 243mm or a little over 9 9/16" So it looks like I'm about 9mm or 3/8" to short... I get the same sort of results if I calculate in terms of blocks - 243/44 is only 5.523 blocks, or with the new number, 243/42 = 5.79 blocks....
shirley_hkg wrote:ex-Gooserider wrote:....
If it does , 4S7P will also fits .
The fifth row has only 3 cells , that they can be arranged on both sides , so still leave you a centre void for Anderson .
shirley_hkg wrote: Actually , we are fitting two 4s9p @135Ah slabs into an ARROW last weekend , that need a bespoke battery box ..
What I am NOT certain of is the exact LENGTH of the 15Ah cells when in blocks....
I have this little utility pinned to the bottom of my screen.
https://joshmadison.com/convert-for-windows/
ex-Gooserider wrote:Here is the edited photo -
expresso wrote:purchase some 15ah blocks and a few 15ah Cells from the USA headway website -
Headway Headquarters wrote:Lithium LiFePO4 Cells by Headway and CALiB
We are moving away from retail and concentrating primarily on wholesale for cells which is the reason for the change up occurring on our website. Our MOQ is 500 pieces for wholesale pricing. We apologize if this has caused any inconveniences. We can direct you to a reputable seller in China if you would like, the costs for the cells will be much lower, yet you will find that with the shipping costs the overall end costs will be very much the same as when purchasing from us.
Gnomatic wrote:ex-Gooserider wrote:Here is the edited photo -
Headway Headquarters used to have that photo on their website, but .....expresso wrote:purchase some 15ah blocks and a few 15ah Cells from the USA headway website -
Not going to work. Headway Headquarters is now wholesale only.Headway Headquarters wrote:Lithium LiFePO4 Cells by Headway and CALiB
expresso wrote:
OH that sucks - i mean they were expensive compared to china but for a quick fast order when you need it - i have used them before - so that leaves us with no one here in the states to buy them now ?
Users browsing this forum: LROBBINS, shirley_hkg and 348 guests
