Postby martin007 » 10 Jun 2018, 14:19
Those 2 PSU already have a buyer?
Postby Burgerman » 10 Jun 2018, 15:35
Charging a chair last night, set 29.4V, and 12A, with 27.2V float. Via XLR plug. Set termination to 0.1A. (thats 100mA. And it worked fine. On Odysseys.
Switched to float as expected around 5 hours after charge, and after 4 hours CV. Then after current fell to almost zero (it says zero, but in fact was around 3 to 6mA, it periodically spikes up to 29.4V for a fraction of a second. Then switched off float till the voltage fell back to around float level. Thats presumable to test if theres sstill a battery there! But its actually a good thing. So you might get away with setting 0.1A transition, if your batteries are healthy.
Makes a fair bit of noise at night though, at low power and is stone cold. So I am considering:
EITHER
a. Remove front fan, fit a 25mm thick rear one only.
b. Fit 2x low power 25mm deep fans, and use two fan resistor cables to slow them further.
Both will quieten it considerably. And overheating wont be an issue as the fan speed will increase if it needs more airflow at high power anyway.
80mm fans come in 2800rpm and above, down to 1100 rpm.
This is slow, 1300 rpm, thicker, quiet at just 10 db and judging by the over the top stock airflow, more than adequate with the front fan gauze replaced with a fingerguard. As I already did. Should be almost inaudible. So I may fit 2. Ordered.
Postby Gnomatic » 10 Jun 2018, 16:12
These draw .18A, vs .27A for the skinny stock ones.
https://www.newegg.com/Product/Product. ... -_-Product
Postby Burgerman » 10 Jun 2018, 16:18
You can get the same affect with a couple of resistor cables... Half the power, half the current, half the noise.
I may just do that. I did try one and it reduced noise a lot.
Postby shirley_hkg » 11 Jun 2018, 02:58
Two new PSUs are checked . Everything is fine . :clap
They are out this morning .
Tracking :
https://www.hongkongpost.hk/en/mail_tracking/index.html
Postby shirley_hkg » 11 Jun 2018, 03:45
Burgerman wrote:Charging a chair last night, set 29.4V, and 12A, with 27.2V float. Via XLR plug. Set termination to 0.1A. (thats 100mA. And it worked fine. On Odysseys.
At first , I took those features as gimmick , and had little thought they will work out .
Glad that they all seem to work . The guy, who developed the mod kits , looks quite dedicated .
It can slso be programmed to shut down completely at a duration with minimal residual current . Tested yesterday . drunk2
Postby Burgerman » 11 Jun 2018, 16:01
As a charger alone, its noisy as it comes. But can be configured for AGM, gel, pure lead etc and iuts accurate enough. It can be configured with .1A end point, and so its better than almost all mobility chargers. And up to 50A...
Postby steves1977uk » 11 Jun 2018, 18:43
In the EEPROM menu E... https://translate.googleusercontent.com ... dWUl-fpcVQ There's settings related to temperature and the 3-stage charging setup, but I'm not touching those until I fully understand what they do.
Postby martin007 » 11 Jun 2018, 18:52
Broken link...
Postby Burgerman » 11 Jun 2018, 18:57
Works fine in internet explorer and firefox. And probably chrome since its a google link...
Postby steves1977uk » 11 Jun 2018, 18:59
Works fine for me as I test links before I post them... :)
Postby Burgerman » 11 Jun 2018, 19:02
Hes probably using a ipod or some other dodgy gear. :fencing
Postby martin007 » 11 Jun 2018, 19:03
With the Opera browser, the link is broken.
With the browser K-Meleon the link works.
Postby Burgerman » 11 Jun 2018, 19:15
Both those browsers are broken by design. Why not firefox or chrome? K-melion is a cut down firefox.
Postby shirley_hkg » 12 Jun 2018, 08:58
shirley_hkg wrote: Two new PSUs are checked . Everything is fine . :clap
Tracking :
To track , click the link and input Item # .
Postby shirley_hkg » 15 Jun 2018, 03:32
US Dollar $ is strong , CNY ¥ is weak .. :dance
Postby shirley_hkg » 15 Jun 2018, 03:55
Final call for PSU group buy .
Currency in HKD $ .
1, PSU + fency outfit (6.5kg) @$1,100.
2, PSU only (5kg) @$860.
3, Satisfaction guaranteed mod kits + psu (diy)
@$590. (5kg)
Postage not included , and can be obtained here : https://www.hongkongpost.hk/en/postage_calculator/
Postby martin007 » 15 Jun 2018, 17:50
I want to buy a PSU.
How much should I pay?
Paypal...?
Thanks.
Postby LROBBINS » 15 Jun 2018, 19:08
Shirley - you didn't reply to my last PM, but I'm about to send you another one.
Postby shirley_hkg » 16 Jun 2018, 02:09
Can you send HKD$ ? That will be the best .
Guys check pm and drop me your Name & Shipping Address
Postby martin007 » 17 Jun 2018, 22:22
Currency in HKD $ .
@$590. (5kg)
I want:
What option is (1,2,3)?
Postby Burgerman » 17 Jun 2018, 22:45
Not sure if 3 is ready fitted. It says DIY!
Postby shirley_hkg » 18 Jun 2018, 02:33
Yes,
3 means we do the modification ourself , to embrace total satisfaction .
Postby shirley_hkg » 18 Jun 2018, 05:03
AIR Parcel arrived at INDIA in 3 days . :dance Let me know when you received it . cheers
Postby Burgerman » 18 Jun 2018, 05:14
Who is "we"?
Still unclear.
I doubt he will be able to do it himself.
Postby shirley_hkg » 18 Jun 2018, 07:07
Burgerman wrote:Who is "we"?
Still unclear.
BUYERs do the mod themselves as I did . Members here can solder well and know electronics. This is the fun part actually . drunk2
Postby Burgerman » 18 Jun 2018, 10:23
He wont be able. And wanted one built and preassembled like mine, steve, etc. At least I think so.
Its why he posted this: viewtopic.php?f=2&t=7670&p=120576#p120532
Postby martin007 » 18 Jun 2018, 17:37
Finally (in my case) : HKD $1,160
Postby Burgerman » 18 Jun 2018, 17:55
martin007 did you understand what I keep asking you, and did you read the posts above??
DIY means YOU fit electronics and make it adjustable. Is this what you want?
PRE ASSEMBLED is what I bought.
Postby martin007 » 18 Jun 2018, 18:01
I understand what you say.
I speak whit shirley_hkg (PM).
"Ready to use PSU + postage is HKD $1,160 in total ."
Users browsing this forum: No registered users and 49 guests
