Burgerman wrote:Charging a chair last night, set 29.4V, and 12A, with 27.2V float. Via XLR plug. Set termination to 0.1A. (thats 100mA. And it worked fine. On Odysseys.
Switched to float as expected around 5 hours after charge, and after 4 hours CV. Then after current fell to almost zero (it says zero, but in fact was around 3 to 6mA, it periodically spikes up to 29.4V for a fraction of a second. Then switched off float till the voltage fell back to around float level. Thats presumable to test if theres sstill a battery there! But its actually a good thing. So you might get away with setting 0.1A transition, if your batteries are healthy.
shirley_hkg wrote: Two new PSUs are checked . Everything is fine .![]()
They are out this morning .
Tracking :
https://www.hongkongpost.hk/en/mail_tracking/index.html
Final call for PSU group buy .
Currency in HKD $ .
1, PSU + fency outfit (6.5kg) @$1,100.
2, PSU only (5kg) @$860.
3, Satisfaction guaranteed mod kits + psu (diy)
@$590. (5kg)
Postage not included , and can be obtained here : https://www.hongkongpost.hk/en/postage_calculator/
Let me know when you received it .
Burgerman wrote:Who is "we"?
Still unclear.
I doubt he will be able to do it himself.
Users browsing this forum: Burgerman, HiltonP, Kande_ian, Superchunk and 603 guests
