ex-Gooserider wrote:$700 is on the VERY high range of what I got for quotes, especially for 'slow-boat' post...
Gnomatic wrote:ex-Gooserider wrote:$700 is on the VERY high range of what I got for quotes, especially for 'slow-boat' post...
Unless I'm mistaken, Shirley is quoting HKD, not USD. Unless I'm mistaken, the HKD/USD ratio right now is 7.78/1, so not so bad.
I'm still interested.
shirley_hkg wrote:Gnomatic wrote:ex-Gooserider wrote:$700 is on the VERY high range of what I got for quotes, especially for 'slow-boat' post...
You are right ...
Vitolds wrote:https://item.taobao.com/item.htm?id=539377155170&toSite=main
expresso wrote:I am back in action
shirley_hkg wrote: This gonna be a hit-and-miss .![]()
shirley_hkg wrote:Manufactures are reluctant to use low cut-off BMS like the one I bought you .
Instead , they are MORE eager to pump up the capacity , by using BMS with high cut-off , 3.75 /3,85 V . Cells will get swelling , in a year or two .
Burgerman wrote:0.007v isn't much. Most multimetres are not that accurate and couldn't measure it. But theres is a reason. It may even be a charger calibration fault. Or slightly bad cell, or bad connection/loose bolt. Its so small that I might ignore it for now. And keep an eye on it.
Users browsing this forum: LROBBINS and 96 guests
