Gnomatic wrote:XT30, XT60, XT90, and SB50 size comparison.
XT30's are tiny!
Burgerman wrote:very very neat!
If I were delivering, frank would be added to the pizza and I would collect the tablets.
Well done, espresso. I can't imagine going 44 miles in my chair
SteveO wrote:For what it's worth, I think you've done a brilliant job. You should be proud of what you've achieved. Well done.
SteveO
rustyjames wrote:Well done, expresso. I can't imagine going 44 miles in my chair
XT30's are tiny!
ex-Gooserider wrote:Worth noting that the picture doesn't show the smaller Anderson PP15/30/45 connectors - they are about one 4th the size of the SB-50, I don't have one in hand for scale, but I'd think they are in the same size range as the XT-90... The current rating is what they can deal with for live make & break connections, they can handle much higher currents as long as they are already connected, essentially same as the wire's nominal rating.... I have seen them used for motor wiring on many chairs, and they are extremely common as actuator connectors in seating systems.
The three size numbers relate to the different contacts available, which accept different wire sizes... The shells are the same. They come in a bunch of different colors so you can do color coding easily, and the shells can be locked together to make any desired size of connector...
expresso wrote:rustyjames wrote:Well done, expresso. I can't imagine going 44 miles in my chair
thanks - Are you from NJ ? you also have a 646 ?
Users browsing this forum: Bing [Bot], jehan, shirley_hkg and 567 guests
