shirley_hkg wrote: There are 1 or 2 who sell modified units @£60.00 .![]()
Full modification for a.
I'd go for that! With the original case.
Gnomatic wrote:Of course, being in the US, I'll need to grab a 110V AC to 220V AC step up converter to run the power supply. But that's not big deal.
Gnomatic wrote:shirley if you can ship to the US, I'd like one of these as well! 60v out, with the fancy case mod.
Burgerman wrote:The rewiring isnt a problem for me.
I would like the mod done, and will swap case myself.
Thanks.
Burgerman wrote:They do 110 to 240 and50 and 60 cycles AC as far as I know.
Most stuff we buy in the EU or china does both. Often without even needing a switch. Because nobody knows where it will end up!
However , it does say 110-240V 50/60Hz already , doesn't it ?
shirley_hkg wrote: Running @117V , power will be cut by half . That is the output current will be limited to 50% of what the constant current being set .
That's said , the seller .
shirley_hkg wrote:And that fency new case too ?![]()
Burgerman wrote:How do they get 110 from single phase 220V? Or is the 220 actually 2 phases? And 110v is N plus a phase? Or they would need twice as many cables into the house.
It should be simple then to run a set of cables and breakers for EU or UK style sockets at 240V for big tools, heaters, power supplies, etc. Makes you wonder why they would want 110 as well. Just gives more room for errors...
Burgerman wrote:None do. Its seperate, you swap it later.
shirley_hkg wrote:Yes , you gonna receive one of these 0-60V / 0-50A psu completed .
And a kit set of the fency outfit .
Users browsing this forum: Kande_ian and 222 guests
