shirley_hkg wrote: Yes . Still available .
Will be on holiday to Seoul for a week .
Policy always changing . Have to re-assure shipping when came back.
Hope to get sin85's OPTIMUS a 270Ah block , so he can ride all day long with his grand daughter .
snaker wrote:@Furio: Firstable I insulated the battery box by a 0.5mm amiang sheet. It's very solid and cheap (about $4 for 1m2). Then I wrapped each pair of cells by a 0.5mm silicone sheet and sticky tapes. I note that the silicone is very durable, 0.5mm is already strong more than enough. The sticky tape is specific to wrap lithium cells. It is very special, I see it the first time. It is made of mica, very sticky, thin but solid.
Links to buy silicone sheets and sticky tapes
https://world.tmall.com/item/5244358338 ... 0936362501
https://world.taobao.com/item/387284724 ... bbceJuyQ1E
I wrapped the pack the same way we make our traditional rice cake![]()
https://www.google.com.vn/search?q=goi+ ... 60&bih=702
Here is the final result
https://photos.app.goo.gl/E8tmjESjqjsB3zhZ7
Air freight : £6.75 / kg to UK ; custom fee included . No more extra at all . That's what I've been told.
expresso wrote:quick question -
the C rate of a Cell - lets say its 150A constant discharge rate -
if using 8 Cells - would that mean its 150A x 8 for the total discharge rate for the Pack ?
is that correct or if not - correct me so i understand
Burgerman wrote:Depends. As an addon? Or as a part of a bigger pack?
It will WORK in both cases. As an addon its OK just about only because its big, at 60Ah, so 3c max? is 3x 60Ah, or 180 max. But those cells wont like it much. They are happier at low dicharge rates.
The headways are 5C continuous, 10C peak.
So a smaller 36Ah headway pack is good for 36Ah x 5 = 180A cont, or 360A peak. So thats safer!
A 60Ah headway could do 5x 60Ah continuous, thats 300A. 600 peak for limited periods. So that keeps us further away from the max they can do, so last longer. This is why the bigger a battery is, the better!
Burgerman wrote:Should be OK, the lead helps too.
shirley_hkg wrote:goodpost Air freight : £6.75 / kg to UK ; custom fee included . No more extra at all . That's what I've been told.![]()
EVE-LF90 , Rated --- 3C (5C max) ; IR @ 0.5mΩ .
90Ah cell , 2017/8/31 NOS @£27.50![]()
* * * * unknow batch NOS @£18.80![]()
Users browsing this forum: rover220 and 588 guests
