Burgerman wrote:That shows your lithium was fully discharged. And say 55Ah from it. And about 15Ah or less from the lead only! So a diode would give you an easy 20% range increase.
shirley_hkg wrote:Don't know how much you've paid .
Taking this CALB 60Ah cell @£12.50 an example , I wouldn't complain to get a 24V-55Ah pack @£100.00.![]()
It costs even less , if you choose other unknown brands.![]()
I won't take lead any more , even if they were given for free , let alone a £650.00 pair of MK gel out of my own pocket .
Burgerman wrote:Any 50 to 100A schottky diode.
https://www.ebay.com/itm/Vishay-VS-100B ... m570.l1313
Free shipping from UK?
Burgerman wrote:Not sure. But we will find out!
Burgerman wrote:Nobody tried this before. So we dont quite know what will happen. For the first few miles you need to monitor the temp of the diode. As it will get hot. To run at high power continuously like up a hill, is the hottest it will get. I think the cables will be enough of a heat sink though. But I am guessing. Its safe to 170C water boils at 100.![]()
You are tester. Did you order a silicon or a schottky diode?
Its small, you will need small ring terminals.
It worked. No time to charge.Burgerman wrote:I would use terminals. They will soak away heat. But soldering could work if you do it fast.
expresso wrote:when i get this thing - i will ask you how to proceed - i cant leave it fully exposed if it gets HOT - it will be in my back pack on top of other things etc, - not a good thing if it gets hot to the point where it can be dangerous -
not sure how i would test it - the large hills are not close to me - by the time i test it on a hill - i be far from home - cant have it fail then -
i though you guys done this before ? maybe i heat shrink it and wrap it that tape i got to wrap the pack with - ?
if it needs to be exposed to have Air keeping it cool - maybe a fuse holder to snap over it - if i can find one that would fit , or work etc, ?
shirley_hkg wrote: I have add-on .
They have bms inside for protection , so it's different to your case .
shirley_hkg wrote: Your new add-on is pretty good actually .
It will out last your P220se .
RELAX , and enjoy it.![]()
