Gnomatic wrote:Nice job! Thats crazy capacity for an add on!
A range of approx 42 + miles is possible with the largest battery option.
Burgerman wrote:What are you guys doing?
And I use 15mm or 1/2 copper pipe out of the garage. Just cut a bunch of short bits to length with a pipe cutter... Flattened in the vice! Clean and shiny when using new tube. Easy to DIY.
I then put them in the drill vice 8 at a time, and use the pillar drill... Drill all at once. Drill 6 or 8mm. Debur with a countersink bit in my hand as copper is soft. You can do 8 or so in about 10 mins. You only need 7.
Burgerman wrote:Cost... Many chairs with r-net are not 120A per motor either. Theres a cheaper 90A one fitted to most chairs. Because they think we dont understand the difference. It has built in actuator control etc and less power. Total cost of upgrading to 120A version with separate seating/lighting module and 120 controller is much more expensive. So just because its r-net doesent mean its 120A.
yes i know theres a 90A model El model i believe - led with no screen - on the JS - i done the research on there website to learn the different control models they offer -
also on the order form its clear and have both - its an upgrade and costs alot more - if going to 8.5 motors on the quickie its required to get the 120A which is 100A most of the times - 120A for a few secs if and when needed -
636 chair 6.5 comes with 90A - 646 8.5 comes with 120A - - you can upgrade the 636 to get the 120A but once going to high speed motors - its a must to configure it with the 120A
snaker wrote:Yes, the whole chair still looks nice and compact. It is even more well-proportioned with the add-on
Users browsing this forum: Bing [Bot], Seafighter and 489 guests
