Burgerman wrote:20A discharge. What on earth did you use to discharge 85Ah into? Never mind, just realised it was 12V 4S...
Burgerman wrote:So you like your PL8?
A good tool if you take advantage of what it can do.
Soldering completed .
Note back view of Female to battery ,
in case you want to clone one yourself .
Burgerman wrote:Depends what the balance current was set to. I set yours low for small cells. It can be 1A. 1000MA. And then even so it is proportional. So the PL8 can use 5 to 100% as it requires, up to your choosen limit.
Scooterman wrote:I wish I had that knowledge
Ah so the balance current can be set by the user, I didn't realise that. Do you choose a value based on the cell mAh and other specs, the same applies to cell chemistry i.e the CV rate and CC rate depending on C-rate of cell? Might it be different for different brands of cells? Is it a learning experience, i.e. Over the years you learnt from experience what charge preset is likely to work best for the cells you want to charge.
Mechniki wrote:cool piece of kit to own then, they get seriously hot? Saw the post regarding the PL 8#2 catching fire and the fault wasn't identified. Something to which I didn't understand (don't own a PL 8). But maybe in a few months time.
steves1977uk wrote:Nope, unless you get a faulty one which expresso did, but he sent it back for a replacement. My first PL8 is 4+ years old and still works fine.
Mechniki wrote:Something to which I didn't understand (don't own a PL 8). But maybe in a few months time.
Burgerman wrote:I got 4. They may stop making them. And in spite of a lot of looking and returning I have yet to find anything that can match it. Or even come close.
Thats okay then I can swap you one for my heinous tyres I’ve currently got for saleBurgerman wrote:I got 4.
Users browsing this forum: shirley_hkg and 115 guests
