Burgerman wrote:Setting parallel charge to say 2 or 5 simply increases CC charge by the same amound. It does absolutely nothing to thermination current if set to manual, as we do. So its useless... Dont use it.
It works in hobby use as we may have say 4 heli packs to charge at once, and termination is set to say 1/20th of CHARGE CURRENT! So x4A charge and terminates 4x the current. We dont do this so dont use it!
I was concerned it was a stupid quest but I'm really pleased I asked now. Better to be safe than sorry
Burgerman wrote:Starting balance at 3.3V UNBALANCES cells for most of the charge since at this voltage the highest cell may well NOT be the fullest one. And the PL8 will take 1A out of it the whole charge... At 3.4V its OK, as long as very slow charge rate. At 3.5V it begins just before its full where the full cells shoot up high. And it prevents overshoot. You can just set to balance only at CV. (Disable the charge entire balance) if you want. And if you charge to 3.500V only, you must do that.
Burgerman wrote:But remember that 3.600V is lower already than the manufacturers 3.650V recommended max. So 3.600 is alreay on the safe/lower side.
Burgerman wrote:Or even 3.500 as long as you set it to balance ONLY AT CV.
Burgerman wrote:Yep!
Burgerman wrote:Yep...
Esp important on laptop or lipo battery packs as these have 200 to 500 FULL cycles.
My now 3 year old laptop battery is as good as new as I told it to charge to 75 to 80% full in the bios. And that the last 20 was out of bounds. So it shuts down. This means I only have the middle 60% to work with.
So in the case below, on some tests on a small phone sized battery, they tried charging to a higher voltage. Look what it does. And have a guess why Tesla charges their batteries to around 85% max?
Again, then, this is why you must fit as many Ah as possible, charge less than full, never go near empty. Lithium hates full, empty, and high currents! Loves to be sat at 30 to 70% and will last forever.
ExpressCharge – Quickly charges the battery using Dell fast-charge technology. Recommended for users who
need the battery to charge within a short period of time. If the system is powered off,then the battery typically
charges to 80% within one hour and 100% in two hours. Charge time may be longer if the system is powered on.
NOTE: The ExpressCharge setting may cause battery health to diminish more quickly than other settings.
Primarily AC – Extends battery life by lowering the charge threshold, so that the battery never charges to 100%
capacity. Recommended for users who primarily operate the system while plugged into an external power
source.
Custom – User selects when the battery starts and stops charging. Recommended for advanced users.
Standard – Fully charges the battery at a moderate rate. This setting provides a balanced approach to extending
battery life while still providing a reasonably fast charging time. Recommended for users who frequently switch
between battery power and external power sources
Modern dell ones do! Actually its even better, it allows you to choose by working day hours, day of week etc too.
Or simple options:ExpressCharge – Quickly charges the battery using Dell fast-charge technology. Recommended for users who
source.
Burgerman wrote:It just uses ohms law. While its charging, or discharging it actually stops, takes voltage measurements OFF LOAD rapidly all the time. You need an occiloscope to see it. So it knows:
Actual unloaded cell voltage.
Loaded cell voltage (charge or discharge amps and voltage)
It can then compare the unloaded voltage, to the loaded voltage at x Amps, and ohms law tells it the resistance. Its doing that all the time, rapidly so you cant see it.
Like this.
Voltage at say 5A CHARGE is hIgher by .15V than it is at 0A. So ohms law can tell you the resistance of 5A and .15V is 0.03Ohm. Thats all its doing, per cell.
http://www.ohmslawcalculator.com/ohms-law-calculator
But it has a boost mode too. Where it takes say 12V and charges at 24... A built in step up inverter. It then works in boost mode. That will cause smoke to come out of your ears. And it may need both systems during a single charge depending on supply and battery voltages.
Users browsing this forum: No registered users and 170 guests
