shirley_hkg wrote: Recharge graph looks solid as a rock .![]()
Burgerman wrote:I remember you saying it was all too complicated for you...
Just like expresso.
Although SM could use an USB PC Keyboard on his Mac.
Even right clicks dont work! So most of the commands and stuff you need is just missing... Stupid things macs. So frustrating to use.
I forgot he wasnt using a proper computer.Even right clicks dont work! So most of the commands and stuff you need is just missing... Stupid things macs. So frustrating to use.
Wait... Does a mac, thats trying to run a windows program, in an emulator or whatever they use, also have no right click?
Burgerman wrote:I forgot he wasnt using a proper computer.Even right clicks dont work! So most of the commands and stuff you need is just missing... Stupid things macs. So frustrating to use.
Dan wrote:@shirley_hkg is there any chance you can give me the over all dimensions of your battery pack? It might give us a better idea of what chairs it will fit.
I'm using a storm 4 X-plore.
And if you will be going to the trouble of getting some for users how much would it be for eight delivered to the UK?
wheelie junkie wrote:Burgerman wrote:I forgot he wasnt using a proper computer.Even right clicks dont work! So most of the commands and stuff you need is just missing... Stupid things macs. So frustrating to use.
There is a right click button that brings up a menu or hold the control key and left click. If you emulate windows and use control click it'll give the standard windows right click selection. Screen grabs depend upon what you want, full screen, just one window or an area you select, shift, command 3,shift command 4 key combinations. Or use Skitch or Parallels toolbox as you usually want to add comments and highlights or resize depending upon where you are uploading to. I tend to screen grab, edit and resize in one app.
I run Mac and Windows together, R Net, Wizard and PL8 all need windows. Windows is a pain, yet again got another update pending and failing to install, another fresh install needed, luckily I store documents and files in mac os, I'll just need to reinstall the apps. Photos hasn't worked for about 6 months and I won't waste more time trying to fix. Never had problems like those 2 on a mac in just short of 30 years. I just want to use my computer not spend hours updating and fixing, I had enough of command line in DOS no need for that 30 years on.
shirley_hkg wrote:My pack hasn't completed yet.![]()
You shouldn't get 8 cells . Go get 16 of them.
Unfortunately I have to wait until I can get someone to measure its battery box but it looking a little tight.Return to Everything Powerchair
Users browsing this forum: No registered users and 332 guests
