Burgerman wrote:The issue with those is that the cells move and the bus bars are rigid. And that they do not sit flat on the terminals so they likely only touch in a couple of places. Because all those battery termonals are not in the exact same plane. So probably helps, but I still dont like solid bus bars. I like a bit of cable between them!
Visualise 2 cans of paint with lids on. And sit them on some not quite level waste ground Now sit a wooden plank on top. It only touches on a few points. But two short bits of plank sit in perfect contact with the tops of the cans. But now they dont line up with each other perfectly in all 3 axis.. So you need a flexible bit in the centre.
Theres a thread here somewhere where shirley built a battery with heavy solid copper bus bars. He swapped to terminals and wires when he couldnt get neat graphs and sensible balancing. It was all over the place. Losing the copper bus bars fixed it totally. He may be delayed right now in the rioting in HK...
Burgerman wrote:Heres 1 example.
Heres my attempt at nickel plating. My first attempt and TOTAL settings guess!![]()
2.7V actually 3.0v but limited by the Amps set to 0.3A. Turns out this is too high, it plated in seconds.
I tried plating a coin and ignoring all the acid bath cleaners, and distilled deionised water baths etc.
I simply cleaned it with washing up soap, as used for dishes, with scotchgbright cloth. For all of 15 secs...
Then straight in the plating bath, after a rinse under the tap. And no gloves, handled by fingers etc. Everything wrong!
So power on for 30 seconds, and at 30C (too cold by all accounts, needs to be 50C? But I have no patience!).
Its super shiny, and totally covered, and its so easy. I dont know what the fuss is about.
Now all my money will be worth more and shinier than other normal peoples money...![]()
FIRST EVER ATTEMPT, 1 WEEK BACK.
Nickel plated copper coin.
Burgerman wrote:Nickel plated cardboard?
Scooterman wrote:Burgerman wrote:Nickel plated cardboard?
Not just any old cardboard, corrugated cardboard![]()
I think it was brass or something similar. What do you think BM?
Burgerman wrote:If they nickel plated it it could be steel, brass, copper or stainless, etc. But, there are ways to nickel plate plastics, or any material. Even cardboard if you really wanted.
shirley_hkg wrote:LROBBINS wrote:Clearly that device is unsuitable, but I do wish someone could find a cell balancing board that would: (1) start balance only near or at the end of CV, (2) dissipate or exchange enough current to balance reasonably quickly (would 3A be enough?). It should be rugged enough to be mounted in the chair and not need any user attention (after initial programming). As it would only be doing something when connected to a charger, it can be a passive balancer that just dissipates energy from the highest cell - the mains watt-hours wasted would be tiny in any case.
You will get one , very soon.![]()
3, absorption further for the highest cell "via controlling the charge rate" , so no more ON /OFF.
4, it starts to scan all cells , and charge the LOWEST CELL INDIVIDUALLY @2A max, one at a time. You program it when to stop, say within certain voltage drop.
Users browsing this forum: Google [Bot], shirley_hkg and 130 guests
