Burgerman wrote:Thats what I expected. It is harder to inflate (more amps) when its got you on it though. But still it will do a day.
Well that's an issue in physics that has me scratching my head!
Seems the issue is the air volume the bladder needs to be more so than the psi. Either way, high psi or larger air volume, will take more amps.
The bladder of this cushion is not going to hold up and does not have enough seating surface area for my liking.
I like the pump you have, IIRC the pump you have puts out 4x the volume of air as this one. Regardless, if you had a choice would you go for a foam perimeter with the small bladder insert OR the entire cushion with air cells held in shape by its cover like a ROHO?
OK yeah! That ball joint at the hip & femur isn'T taking downward pressure while seated.
Burgerman wrote:The bones that need protection are as image. Around 140 to 160mm apart.
The hips are not in danger seated and can take weight off the important bits. So you should ideally build the cushion fiam up around your thighs and only need the air cells in the middle.
Hips are in danger turned on a bed.
Because I can move and stand even if only briefly gives me a bias and my opinion must be qualified by my circumstances. My issues are certainly different than others. We are each using the tools we have to the best of our ability. The air cushion has helped me.
My objection to the higher pressure stems from the chair I'm using it in and the instability the high pressure causes. If I had room for a chair... say with arms... maybe with a seat belt. When blown up harder, the instability causes me to constantly use my legs to keep position, causing fatigue which is so much a problem with MS. I've had so much pressure on my feet at times that my feet have gone numb which then makes me at greater frisk of falls.
Burgerman wrote: Attach a signature (signatures can be altered via the UCP)
Notify me when a reply is posted
EXPAND VIEW TOPIC REVIEW: OWNER'S MANUAL FOR APEX SEDENS 500
Re: Owner's manual for Apex Sedens 500
Post by Burgerman » Tue Aug 27, 2019 4:07 am
This is a jay fusion AIR cushion. (Jay Balance in the UK. Theres Air or Gel verions. This does not alternate. This is what you need for stability and "comfort".
youtu.be/nIeLwNP5DSM
I would like the very same, with a small area - only under the sitting bones - that alternates. The reason this works better is because the outer edges of the cusion, and the part under your legs takes much of the weight. The sitting bones that develop sores due to pressure then have less load on them.
Thats why the cushion from Ride works.
Its also why THIS cushion, would allow you to use air and low pressure. And it would reduce pressure on the relevant bits, while giving YOU stability.
https://cdn.shopify.com/s/files/1/0730/ ... 4x1024.jpg
Post by Burgerman » Tue Aug 27, 2019 3:37 am
I think I respectfully disagree about high pressure but I do agree that alternating is necessary for healing if injury has already occurred.
No. The whole point is to PREVENT a pressure ulcer. Pressure on one spot continuously, cuts off the oxygen (because it crushes the fine capailiaries in your skin). The whole point of having 2 groups of cells is to alternate and so it rests any parts of your backside that are suffereing, and allows blood to oxygenate the bits you were previously sitting on. The lower the pressure difference between bladders the less this differential occurs. You need adequate pressure on the high spot to lift the opposite bits of your backside off the deck.
Once its occured (a red mark, or worse if you dont catch it in time), you should be getting off the chair completely, and laying flat, to remove most of the pressure from your backside. And to turn 4 hours apart, left then right until it has healed and completely gone before attempting to sit again. If not you will end up in surgery...
May be. But you lose the purpose of its design by just inflating it to low pressure and sitting on it without alternating.
You cannot and should not try to have the whole cushion under you.
The problem you have is that you need a foam cushion, with a SMALLER air section that goes only under the bones under your backside. It is stable for me because I need a 20 inch cushion. So I have a firm cushion with the air cells only under the important bits. What you have is too big for you. So you are sitting only on air.
Users browsing this forum: Kande_ian, shirley_hkg and 90 guests
