You're table is useful espresso. 9 Awg should fit snug in 6mm lug
Burgerman wrote:Here ya go: https://www.kayfast.co.uk/information/T ... -Fasteners
Or https://www.essentracomponents.com/en-g ... teel-bolts
I built a lot of stuff, and broke everything possible many times over. Thats how I learn! The link above makes a drama out of it.
A tiny dab of grease means you wont ever get the problem. You should always grease or oil all threads (or loctite them), anyway!
Its dry clean clean stainless steel thats the problem. Seldom or never happens with normal steel. Unless bare steel. But steel bolts are zinc, cadmium, or nickel plated. Or otherwise coated and that prevents it too.
shirley_hkg wrote: I like this SS M4 flange lock nut.
Large contact ,
Plain base,
Thick means more threads .
Will grease it for perfection .![]()
Burgerman wrote:Without seizing and unscrewing the stud from the battery.
Burgerman wrote:Yes, just a smear on the top bit where the nut goes.
I know which ones you have, but you keep calling them nylon nuts, and it will confuse people reading this later that dont realise you mean Nyloc.
Users browsing this forum: Burgerman, emilevirus, JMGarage, snaker, Yennek, yeshelp and 263 guests
