Burgerman wrote:I dont have windows store on Windows 10 version I use. Thank god. How can I get a copy to look at?
snaker wrote:I have ported the PL8 Remote app to Windows 10 and published it on Windows Store. As it runs on Windows, it is able to communicate with the PL8 charger through both Bluetooth or USB cable. If you do not have BT yet, you still can use it with your USB cable. This is an initial version, let me know if you want to add more features or more sophisticated graphs.
Link to install the app (from Windows Store):
https://www.microsoft.com/en-us/p/pl8-r ... verviewtab
Video of installing the app from Windows Store:
https://youtu.be/zbQC24pUKSs
Video of using the app:
https://youtu.be/htKC95rLzDk
Win10 Ltsc allows installing Windows Store.
expresso wrote:i got it on my laptop - - now to figure it out - so this is a computer app ? its not installed on a phone ?
the drop down box to choose a connection and preset show nothing - is it because its not connected to the PL8 yet - ?
ICEUK wrote:expresso wrote:Whow I guess I stick to the wire only[/quote
Expresso, i done the bt mod internally and you can still use the wire for updating, i will do my other 2 Pl8s would a video of the installation be of use to you?
snaker wrote:I am going to make another external BT box. I will post all components and step by step to make it. It is very simple and easy and SAFE and 100% work. Total cost is also cheap, less than $12.
Burgerman wrote:Woody will send this:
https://www.ebay.co.uk/itm/BT06-Bluetoo ... SwFLReuGR3
Or similar.
You provide it 5V and 0V. From inside the PL8 via a power supply like this: Or similar. Connect its input to the PL8 input wires by soldering to the board. Feed its 5V to the BT boards 5V and 0V above. https://www.ebay.co.uk/itm/2-6S-Step-Do ... SwEOhfl8yJ
Then you need one small low drop diode. To connect the SEND and RECEIVE down 1 wire. And also the plus and minus 5V down a normal servo wire to outside the case. With a small wire loop. The BT and regulator stay inside the PL8. The wire is a loop that plugs into where the PL8 has its 3 pin ouput.
and supplying the power supply from the PL8 is that from the PL8's power supply input?
rickystyx wrote:you are a hero - thank you
Users browsing this forum: JMGarage and 191 guests
