foghornleghorn wrote:
10 x male to female lead posted to the UK - how much paypal, shirley ?
foghornleghorn wrote:Only interested in 8s for wheelchair charging. Any of the multi boards has always seemed like extra for no point and ….
HKD $186.
shirley_hkg wrote:Burgerman wrote:You dont need ANY balance connector to charge ONE cell.
You just need the correct preset...
Really ?
It seems that's more accurate with balance port being fed .
Yes I found that out last night. The pl8 kicked out an error with 2 balance wires connected on a single cell. But it worked without balance wires. Think I need to look at some other presets.
Arima wrote:
Shirley I'd like to get 10 of the pigtails if possible please. Male (the one that goes into the pl8) on 1 end. I'll refit a JST-XH on the other end. !
Burgerman wrote:Did you fully charge each cell before assembly?
What is the capacity of the pack?
Please post the preset here.
And are you using the latest 3.5 or 3.6 firmware?
Burgerman wrote:Ah...
THAT code means you are using an unbalanced preset, with a balance wire... Or you have it set to FMA balance wiring mode.
As previously asked. What Ah? 15? If so I will post a preset for that.
I can post a NON balance connector preset. Or a balance wire preset. Which is not needed for 1 cell or many cells in parallel.
I suspect that the gel undergoes an endothermic phase change when heated. Heat is absorbed in the process, and later released (slowly) back to the environment after the source of heat is removed.
Users browsing this forum: LROBBINS, shirley_hkg and 661 guests
