Burgerman wrote:Depends on length really. The longer they are the thicker the wires need to be or balancing will be slow and less accurate.
Burgerman wrote:No. But it will feel "sharper" and so you may want or need to lower the motor compensation by say 5%.
expresso wrote:your do fine - i was and still am a beginner - i had nothing at all - i needed to buy every little single item and never used a solder - or crimper or anything - it was a challenge thats for sure - but after the first pack - i learned better ways to do it- better ways to crimp larger cables and solder them better etc
the charge cable was a job to learn - i did manage to ruin one charge connector - but the rest all completed and in use - all work - still today though - if i have to make one - i get a stressed - but manage to get it done if having the right helper - i can do it in a day or else a few days -
one day just to prep - another day to do it
if you are using two connectors - one for the power cables and another just for the balance - it will be easier - and you can use the 10awg for the power that way - you have room - the connectors i used - i didnt have room - was hard enough to fit 12awg in there - going larger cant hurt - but not smaller than 12awg for the charge cable at least
doin these kind of cells are easier - my first pack was the headways - 56 cells to charge - discharge arrange - build recharge etc, alot more little details and cabling involved - and so far so good still in my chair going on 6 years - i havnt opened that battery box to check in 5 years -and dont plan to either
i may run a Cap. test one day to see how much i have left in there - its 105ah when new - wonder what it is now -- last i remember i did a bit over 30 miles - and used up about 90ah - not too bad still
fishinjunky wrote:Thanks everyone for all the help
Tomorrow I will be purchasing my cells and components (after triple checking my battery box measurements)
I won't be posting my over all cost or list the components because I don't think it's a accurate representation of the price to build one. I had to get everything but a solder gun an socket set so I was starting from scratch including needing a charger and psu.
I'm a complete beginner so it will be interesting to see how I do
Arima wrote:fishinjunky wrote:Thanks everyone for all the help
It all adds up quick but it's hard to get anything done without tools and all the bits. You got this.
fishinjunky wrote:Do you guys think 8 of the 230ah cells I posted above will fit my box?
Box measurements:
Length: 342mm
They are exactly 173mm long .
You will need a few mm more , and insulation too.
shirley_hkg wrote:fishinjunky wrote:Do you guys think 8 of the 230ah cells I posted above will fit my box?
Box measurements:
Length: 342mm
Box measurements:
Length: 342mm
Width: 291mm
Hight: 254
Also the cable in the pic with a label and fuses can I use a Anderson sb50 to connect it instead of having it " hard wired " like it is?
Users browsing this forum: Burgerman, rover220, sergey0 and 545 guests
