Burgerman wrote:Bcause high internal self discharge? Check balance by topping up in a few days.
ICEUK wrote:70% discharge is my limit,. I don't always fully charge pack maybe every two weeks I do a full charge to 3.6volts. my cells didn't come with studs but red loctite works fine you just have to make sure all threads are super clean
Burgerman wrote:Best not to go too low. So maybe on average 70% discharged. Occasionally 85% or so. Not critical as long as you stay above 3v per cell unloaded.
Burgerman wrote:All that happens s that it will take longer if longer. Remember that we are talking about a couple of mV here and adding a 2 amp load to one end of a long wire means the resistance causes a difference in voltage at each end of the wire. Try it.
Burgerman wrote:You always heat the thing you are soldering. When its hot enough, that "thing" if it clean, fluxed, then will melt the solder as you apply it and it fuses to the metal. It will be hot enough for the solder to follow the flux and be drawn into the joint like magic. Capilliary attraction. Never heat the solder. Also once the solder has run into the joint STOP HEATING the joint immediatly!!! And so you need to add adequate solder pretty quickly.
Whole process should take 3 to 4 secs after the solder begins to run. No longer or you will burn the flux, oxydise everything and melt insulation.
This below, is an incorrectly sized anderson terminal. It isnt the best way to crimp. But it makes the process of handling it, adding flux/solder simple and allows a one handed idiot proof solder joint. Assemble, and heat...
https://www.wheelchairdriver.com/crimp-solder.htm
Crimping alone will oxidise, and give different resistance as it ages as andersons and most crimps dont have enough metal in them. So its possible to pull them out too... Soldering fills all voids, prevents future himidity or oxygen from getting into the joint and so the resistance is both low, and STAYS that way. t also icreases physical strength. Its never coming out. Its always easier if you use TINNED wires too. If copper be very sure its clean and oxide free.
I'm making new charge and power cables. Burgerman wrote:Buy a large roll. That will be gone or lost in no time.
fishinjunky wrote:I'm noticing with the icharger that more resistance causes more voltage drop an when the iCharger compensates if the voltage goes to high it goes into cv phase right away or very early taking FOREVER to charge.
Users browsing this forum: emilevirus, foghornleghorn, yeshelp and 111 guests
