Burgerman wrote:Lipo as used in hobby stuff and lithium ion as used in phones, teslas, laptops etc all drop voltage reliably as they discharge in a linear fashion. So cell balance and state of charge are easy to monitor or do at any voltage or state of charge.
Dont worry about that rude poster you wasted time answering, it was I think, that ignorant frenchman with a bad attitude that isnt welcome here so he is gone. For the 3rd time...
Burgerman wrote:Dont worry about that rude poster you wasted time answering, it was I think, that ignorant frenchman with a bad attitude that isnt welcome here so he is gone. For the 3rd time...
fishinjunky wrote:lets put together our theories for my issues with icharger. That way we can test our theories an narrow down these issues and try to find solutions.
possible theories for the icharger going into c/v early or right away:
1. buggy / unoptimized firmware
2. bad connections / bad solder joints or less than perfect connections / solder joints
3. beginner error in programing the icharger
4. resistance causing voltage drop making the icharger compensate with higher voltage causing early c/v phase
5. cell is already mostly charged. ( i already tested this by discharging first to be sure )
also has anyone tried using MG chemicals 847 carbon connective paste for improving connections. I think the small surface area of the welded studs isnt giving a very good connection. Would this stuff help or just add more resistance?
https://www.amazon.com/MG-Chemicals-Car ... X3VG&psc=1
Burgerman wrote:I have 4 chargers and no children. Thats the way I like it. I have no idea which way up they go.
Burgerman wrote:The difference between LIPO and LITr yHIUM ION.
LIPO, Can be charged and discharged at up to 12C and 130C, so super high currents, and very very dangerous... Can be discharged to 3.6 or 3.7V safely. 4.2V charge.
LITHIUM ION, slightly more energy dense. Cannot do more than 1C charge or prefereably less. Or between 1 and 20C discharge depending on actual cell specs. And can be discharged down to 2.5V typically. 4.2v charge. Also can be dangerous but not as bad as lipo.
Burgerman wrote:Seriously I dont think iChargers are bad. If I had no pl8 left I would be fine to use one. They just lack the real control, graphing software development and like expresso that would be a serious downgrade and be missed. And they only other thing is that they have no proper way to set termination current other than as a percentage of charge current. Most hobby chargers do that too, as its a dumbed down way to decide when charge ends. Recently when there was a firmware update to allow it to go to 1% after years of ignoring the requests to fix that, so in the past it made them a bad choice to charge big packs that were high impedance compared to the typical lipo pack that hobby users bought them for mostly.
Even now it means that if you reduce or increase the charge rate amps you also have to do a little mental maths to figure out what the correct termination current then is. If there is one... It may not go low enough for some packs at high charge rates. Will it still charge them? Yes. But will stop a touch too fast to allow the large high impedance cells to level up properly. Does it allow you to set say a fraction of a percent?
Lets say you were to charge a 40Ah odyssey. Correct 2 stage charge profile reccomended for cyclic use says charge at 14.7V until 1000thC at the 20h rate is achieved. Thats a terminaton current of 40mA. So would need a charge termination of 0.1 % of the charge current. Thats the same issue if you charge a lifepo4 pack at the 1C rate. Although that would need around 0.2% to 0.4% of the 40A charge rate. But 1% that they now allow is just about enough on life.
Burgerman wrote:When soldering, you MUST wtch the solder run into the joint and flow freely following the flux. Once you see that happen all is good. I used to do house plumbing and central heating. My dads company. I regularly did a whole house, hundreds of soldered fitting on pipes. I never evn bothered checking soldered joints. Once you see the solder melt and flow then theres no need. They just cant leak.
Always allow the materials you are heating to melt the solder. Not the iron... Otherwise you are just attempting to stick it on!
Burgerman wrote:This below, is an incorrectly sized anderson terminal. It isnt the best way to crimp. But it makes the process of handling it, adding flux/solder simple and allows a one handed idiot proof solder joint. Assemble, and heat...
https://www.wheelchairdriver.com/crimp-solder.htm
. i just need to slow down a little an completely LISTEN to you experienced guys) i would like a torque wrench for consistency. Im sure most of you more experienced guys can go by feel for the right torque but my mom doesnt have that experience.fishinjunky wrote:Got the charging leads done I'm getting around 0.3v voltage drop 3ft total cable length (this is charging a single individual cell) is that accessible?
A little over 2 weeks ago I charged 7 cells to 3.6v individually. I'm just now charging the 8th cell individually to 3.6v . Will I need to charge the other 7 agian before assembling the pack? Or will they be close enough to the 8th cell?
Users browsing this forum: Burgerman, emilevirus, LROBBINS, Raro, Seafighter and 79 guests
