OK just had my ZXD passed to me on my bed!
Do as you did in the vid, choose your voltage, when it stops dimming then TURN the knob left (DO NOT PRESS IT) ... Now its set to your new settings and also stays whenever you power it up.
Mine was set to 20V and now set to 22V. Also was set to 40A and now set to 50A. Took seconds.
Dig your green nails...
Gnomatic wrote:It needed re calibrated. Now behaving (and charging!) as I expect.
Thanks shirley for posting the instructions!
But I can also set any current or voltage
Once there, I press the knob and it kicks me out to the main screen, with my desired voltage. Same if I'm now if I adjust current. That's how both my ZXD's behave.
At which point you can get it to save (keep) the new setting by NOT pressing the button, but by rotating it left or right instead first.
Users browsing this forum: emilevirus, JMGarage, Mkpet13, Raro, slomobile and 159 guests
