Permobil F5 – Battery Size and Alternative Controls
Re: Permobil F5 – Battery Size and Alternative Controls
Postby shirley_hkg » 02 Oct 2025, 10:21
fordragon88 wrote: How will it work without a BMS? And how do I charge it? I don't have a PL8 (I don't even know what this is :mrgreen: ).
Although I can supply decent used PL8, I also recommend BMS.
Modern programmable, bluetooth connected BMS, with 1A~2A balance current (as below), will do a decent job .
You can charge it via any charger if you don't mind long charging time. You may charge it with a more powerful psu, like ZXD2400.
Burgerman wrote: a BMS does many things you dont want in a chair, like chopping off power completely every time it decides to... Which is dangerous to the control system, and you.
And they do a crap job of charging too...
Therefor, we use BMS for CHARGING ONLY.
Power your wheelchair from lithium battery DIRECTLY.
Postby shirley_hkg » 02 Oct 2025, 10:41
Postby fordragon88 » 02 Oct 2025, 11:17
shirley_hkg wrote:Jefferso have been using BMS too.
https://www.wheelchairdriver.com/board/ ... =2&t=12583
I didn't notice this message. For some reason, I thought he built it without BMS. :lol:
fordragon88
Postby shirley_hkg » 02 Oct 2025, 11:22
Yes, he recharge his chair via PL8 at home, whereas through an external BMS on vacation.
Postby Burgerman » 03 Oct 2025, 00:26
Head spinning?
Now the smoke is coming out too.
He charges via a PL8 normally.
When on holiday, PL8 lots bigger as it needs a power supply as well. So he uses a BMS but not on the chair. Theres little space to fit one. So used externally, with a power supply. You can do that with a ZXD supply too.
Postby fordragon88 » Today, 02:50
Post update;
I replaced the batteries on my 2022 Permobil F5 with lithium batteries using JK-BMS. I was able to install eight 105 Ah EVE cells.
I was also given another 2019 Permobil F5 as a gift.
Due to my arms becoming extremely weak, I've started using a chin control joystick. I'm transferred over the backrest to get a deeper seating position. I have nowhere to attach the chin control joystick without it getting in the way during transfers. Does anyone know of any inexpensive chin control mounts?
fordragon88
Postby shirley_hkg » Today, 03:37
Chin Controlled Wheelchair Challenge (part two) – CoHo Ecovillage
https://share.google/BkAt0eYRpAfjD0w45
Users browsing this forum: Bing [Bot], Juggler258, shirley_hkg and 1013 guests
