I've been playing around with Woodygb's sketches and these cells allow for so many layouts, provided you keep the 8 (2 x 4) cell-groups to get 24v.
Using 6, 7, 8 or 9-cell groups gives you 72, 84, 96 or 108 (lithium) ah packs.
Burgerman wrote:You can do 4 cells to each (7 cell) balance connector.
Or 7 to the first one (a) and 1 to the other one (b).
All can be routed through one D connector on the chair. Keep all balance wires short, or less short and a bit fatter that the short ones...
Burgerman wrote:Yep, but I use a single connector on my 13s pack on the chair, for ease of use..
Burgerman wrote:The charger charges the lot, in series, via the thick wires at up to 550 watts, or 20 amps, whichever comes first.
The balance taps, dont require any board, go straight to the chargers balance connections. As it charges, ANY cell that goes above 3.600v has a 1 to 300ma "brake" or pull down applied via the tap as required.
And if this isnt adequate to hold the cell to 3.600 during charge, the charger lowers the max charge amps, until it absolutely is enough. In an extreme situation, with out of balance cells, this can result in a max charge rate, at the end of charge of just 300ma, As more would sent a cell, or cells, higher than 3.600v.
Burgerman wrote:The balance circuits pull down a high cell only. Or pull down all the cells other than a low one as needed. The extra power goie in via the heavier charge wires.
As for the size of these then the relatively small ones are fine in SHORT lengths. As when charging mopdel heli packs. But I use a short 4 inch long 4mm to anderson connector cable. And then everything is 8 guage from here on. Anderson connectors for parallel, dont need to be as fat since half the current goes down each.
See these cables:
Lord Chatterley wrote:Burgerman wrote:You can do 4 cells to each (7 cell) balance connector.
Like this-
LC
Like this-
LC
Burgerman wrote:Yep.
The thing with lithiums is that they are not really 3.2v or 3.3v Thats a nominal figure. They are generally 3.4 or above for at least half the discharge cycle.
When you charge FOUR cells you do so at 3.600v x 4 = 14.400. Exactly the same as lead batteries. The difference is that they will STAY at 14.4v for a very long time and only drop a fraction, where the lead batt drops instantly to say 13.2 and eventually 12.8v ish.
So a fully charged 4 cell lithium phosphate stays at the 14.40V you chargeD it to.
Some are 3.6v some 3.65v, 3.7v... But the last "bit" doesent do anything. 1/1000 of an amp hour will send the voltage from 3.55 to 4v plus! This is why balancing and care is needed. So almost every charger is 3.60v CC/CV.
As you use the chair, the volts will fall from 3.6 (14.4v) to 3.35 to 3.40 in the first few meters. It will then stay exactly the same and only drop a tenth of a volt - even under load on a hill - for say the next 15 miles. And lose another 1/10th only over the next 15 miles... Then it will drop off a cliff. And fall very fast at about 95 percent depleted. At this point its done. The next half a mile will see the volts drop not by 10ths of a volt but by a volt, and after that its not good for the battery.... But its easy to see/feel this happen as it will fall from 3.2 volts to 30 percent less. And will slow accordingly. So just stop and do not try to drive.
The other thing is that when you come to a hill (do a wheelie, climb a ramp etc) the volts of a lead battery drop like a rock due to the surface charge (peukert) affect. Lithiums do not change. They stay exactly the same.
Users browsing this forum: emilevirus, shirley_hkg, Yennek and 130 guests
