Burgerman wrote:But it surely doesn't actually help anything.
He still has to configure the charger correctly first. Ie capacity, cell count, charge amps, charge CV point, TVS, timer off, name the memory, etc, and set charger input amp/volt, weather its on board or on a table...
Then additionally wire the thing up on the chair, modify it to work with some extra logic chip to start it, and then after all of that, he still has to plug in the power supply to the wall/chair then push the go button as before? It saves one simple balance connector, while adding a lot of work/complication. And it means finding space for the charger and another box on board the chair and there's not much space..
What am I not seeing? I just don't see how this is easier. But if you guys do, can figure out how to do it, then it will work - just exactly the same!
If having 2 connectors is confusing (!) just use a single one with 11 wires in it... Like a printer parallel port one.
I mostly want to be able to charge from a wall socket wherever I'm using the charger, and it is more of a pain to have to haul around both the Hyperion and a bench supply - not to mention that the combination probably is heavier and bulkier than an integrated unit would be....
Burgerman wrote:Grp 34s are a lot small for 7.5mph geared powerchair. Range and battery service life will be a bit dismal.Are you sure grp24s do not fit the same space or is it a seating thing (lower batteries)?
Good information, thank you.Burgerman wrote:Measure it.
A group 24 can be UP TO 245mm tall. Inc terminals. Most are not esp when used in powerchairs, and many are also using a flat threaded hole for a terminal.
A 6 cell tall lithium pack is exactly 240mm tall.
The best battery option then is a 68Ah group 34 Odyssey. Its lower, and has a USABLE accessible capacity greater than most 70Ah or bigger Group 24s.
Users browsing this forum: No registered users and 46 guests
