gologen wrote:I want to show how i set connection to powerchair. May be it can help somebody.
So. Driver for my device installed. First plug in
In Devices Manager - Ports(COM & LPT). Assigned Com Port number 11 (can be different).
This port even not appears in the 1314 PCPS
I changet port number to 1 (manual says Com1 or Com2)
gologen wrote:Name of this file is LXN4py2s.dll. You should unzip and copy this file to program's folder (C:\Program Files\1314-4401 PC PROGRAMMING STATION\) and change original LXN4py2s.dll (NetPorty driver).
Next. You should copy file QM_USB.dll (USB-CAN driver) to same folder. You get this file from seller when you purchase USB-CAN device.
Raynentye wrote:I wasn't sent the QM_USB.dll file along with the converter.
woodygb wrote:I've put together a quick post that should help others with the Q logic ...as it's got mixed in with the PGDT Thread.
viewtopic.php?f=2&t=2757
Raynentye wrote:
I recommend going to eBay
Users browsing this forum: Burgerman, emilevirus, iansp, martin007 and 159 guests
