woodygb wrote:Just putting a neutrik plug on the end of the scooter lead doesn't work...I did briefly try that myself..
It would be easier to just make the USB lead.
I will however revisit ( sometime ) the Scooter - Powerchair conversion adapter.
woodygb wrote:Any radio programming cable ( KPG Baofeng etc ) seem to work with the addition of the diode.
There appears to be NO SET colour for the wires ...the wire colours seem to vary depending on the whim of the Chinese supplier of the cable.
Popping the case is the only way to be absolutely sure.... you should however be able to identify the earth wire using a multimeter and check continuity between the metal USB housing and the various wires that you have once the plug is cut off.
You then have a 50-50 chance of getting the diode in the correct wire. ... NO harm will become anything if you have the TX /RX the wrong way around.
woodygb wrote:The file that you've linked to is CURTIS 1314 software ..and it's DEAD.
What make of controller has your Jazzy got?
bluegizmo83 wrote:woodygb wrote:The file that you've linked to is CURTIS 1314 software ..and it's DEAD.
Thank you for the link you provided on my other post!
How do I identify which controller my Jazzy has? The only numbers I see on the joystick are: DWR1234L799 Rev C
CONTROLLER, JOYSTICK MODULE, CURTIS NE PLUS, 6 KEY, SWITCH JACKS AND ACTUATORS, H-1111-268, (CURTIS: 17905700)
woodygb wrote:NE PLUS CTLDC 1560 JOYSTICK
http://www.ebay.com/itm/NE-PLUS-CTLDC-1 ... 1065694204
Users browsing this forum: No registered users and 221 guests
