i am dead and her chair is still fine - so depends on Chair
terry2 wrote:Thanks guys
I will be keeping an eye on this thread. @expresso can you take pictures when it's finished please.
i will follow this setup - the top first and then connect the bottom as in this picture - just to be sure - on the bottom part - i will do as in this picture - i would only have to do one side on the bottom like in the picture - Not both rolls of cells
if i am correct ?
Burgerman wrote:i will follow this setup - the top first and then connect the bottom as in this picture - just to be sure - on the bottom part - i will do as in this picture - i would only have to do one side on the bottom like in the picture - Not both rolls of cellsif i am correct ?
This was my point a lot of posts back. You NEED to be correct, and know you ARE correct and know why you are correct rather than trying to follow someone else's photos... And making an expensive mistake.i would only have to do one side on the bottom like in the picture - Not both rolls of cells
Of course you must do both rows, top and bottom! A cell cannot do ANYTHING with one end only connected!![]()
This is exactly why I asked you to study those simple hobby battery interactive pages designed to teach amateur hobby guys the same thing.
So if the picture is correct just as it is ? then thats how i will do it - i know i need to know why its correct that way - i have an idea but i am not sure 100% - and i have no one here that knows it either - so its me and your help
I did look at them - i didnt mean both rolls - Top and bottom - in that sentence - what i meant was - the top as in the picture - then flip it over the bottom - just where the red marks are ? one roll of cells on the bottom only or both rolls on the bottom ? that was what i wanted to know
Burgerman wrote:http://scriptasylum.com/rc_speed/lipo.html
This really is as clear and simple as this is ever going to get. In dumbed down simplicated graphics.
flagman1776 wrote:Your picture is fine. You are over thinking this & confusing yourself. What is in the photo is a battery pack. A 2P (parrallel), 8S (series) battery pack, to be technical. If the cells were charged, you could run on it... Until the pack is dead. Then you need to charge it.
However, to charge it, with a smart charger OR BMS needs balance wires... they connect to the Smart Charger balance port or the BMS balance port.
Think of the balance wires, in term of a single cell. Each cell needs 2 balance wires (one to the cell plus, one to the cell minus) to know what THAT cell's condition is. When you have a series, the minus wire from the previous cell is also the plus wire of the next cell... and so on. So a 8 series requires just 9 thin balance wires. They balance wires plug into the Smart Charger or BMS IN ORDER & the circuits do the work of sorting the cells & charging each correctly.
Burgerman wrote:Remember that.
When you assemble these cells and bus bars, they are live. You cant turn off a cell. Each one can produce hundreds or thousands of amps if shorted out. So you need to do the following to be safe.
1. Work carefully, because a dropped tool or bus bar (connector part with 2 holes in it) can short out cells. Much heat and sparks will be produced.
2. Wear eye glasses and rubber gloves, and be careful! You cant get a shock, volts too low. But you can be burned.
3. Be aware! Don't try and join the wrong terminals!!!
expresso wrote:another way - - top and bottom view
Burgerman wrote:Its why I keep telling him to learn why so HE knows its wrong, and not try and copy things.
Users browsing this forum: emilevirus, fordragon88 and 390 guests
