Burgerman wrote:When done, I challenge you to do full distance in a day. 105Ah will double+ your range. If you use the addon as well, you should get 3.5x the range or more.
Burgerman wrote:Just be really really sure that every bolt is tight. Theres a lot, and one loose one causes havoc and is hard to fix later. Check both ends at least 3 times, mark with a marker pen as you go. Every time I see a problem it is inevitably a loose bolt...
Scollard wrote:Yep. Only on one side. Will put the balance wires on the opposite side but that should be no problem as they are thin. 12 AWG will be just fine to attach the 7th row.
Black or red row at the back of the chair?
Looking at the chair from the back, what side does the Anderson connector go on and what side the charger cable?
You need to make up 4 cables for the bottom of the pack. Make them all 16-18 inches long and you will cut them to the proper length when you install the 7th row. These 4 cables need a ring terminal on one side only so far. You will install them on the 1,3,5,7 rows of the busbars on the bottom of the pack. Remember the bottom rows are labeled 1,3,5,7 and the top is 5 rows labeled 0,2,4,6,8. Just like the add on.
whats good about doing this chair is my Rnet can tell me the Miles
Scollard wrote:Yes, if possible put a thin sheet of rubber between the 7th row and the top of the big pack.
expresso wrote:i have her pull on it
Scollard wrote:Yes Expresso. Exactly what I was thinking. Add-on cable and 7th row bottom wires on one side and balance wires, charge wires and chair power on the other.
You see how the 7th row is going to connect now. The wires from the bottom will connect to the bottom of the 7th row and you will need 5 short wires to connect the tops.
Remember when you flip the pack to busbar up the bottom you can now short circuit the battery.
You should probably put on the balance wires and completely loctite the bottom of the large pack, then drop it into the tray and complete all the remaining wiring. You can put the charge wires and the chair wires anywhere along the rows labeled 0 and 8. So you could actually put then under the 7th row if you hook them up before adding the 7th row.
You don't have to completely cover the top with rubber. It would just be safer to have a rubber barrier between the 7th row and the large pack. You only need it big enough to do one side of the 7th row.
steves1977uk wrote:expresso wrote:i have her pull on it
Pull on what???![]()
Scollard wrote:It will be 9" high, or a sliver more.
Yes connect the balance wires 1,3,5,7 and the four 7th row wires to 1,3,5,7 as well.
Yes, you need to busbar the 7th row. There will be four 2 hole busbars making rows 1,3,5,7 on the bottom. That is where the 4 long wires will attach. and there will be three 2 hole busbars on the top making rows 2,4,6. Rows 0 and 8 are just the single battery tops, black for 0 and red for 8. You will use 5 short wires to connect the top of the 7th row to the top of the big pack.
Users browsing this forum: emilevirus and 91 guests
