I use 2 pl8 chargers at once to charge my 45V pack at 40 + 40 Amps. Sounds quite busy! 2x 30v 40A power supplies as well. But doesent take long. So soon goes silent again.
anything new i want to ride to or go etc, - he gets worried - his battery - this or that etc, - makes up new reasons not to - i dont want to waste time hanging around the same area all the time
but he has to fund it - this way its his money being lost when it dosnt work as planned with the BMS -
if he does it the way i did - no BMS - thanks to you - then i help him if he makes
steves1977uk wrote:http://www.majorgeeks.com/mg/sortname/windows_10_fixes.html Most Windows 10 privacy apps are listed here.
thats pretty good - i am happy so far - its solid - fast - i wonder at what point would i loose a green bar on my joystick - maybe after 35 miles or at least 30 miles - i know what your going to say - dont worry about the joystick lights etc,
Burgerman wrote:thats pretty good - i am happy so far - its solid - fast - i wonder at what point would i loose a green bar on my joystick - maybe after 35 miles or at least 30 miles - i know what your going to say - dont worry about the joystick lights etc,
On the full pack chair. Once you begin losing lights then it will lose them fast. Very fast. When lithium is done its done! If you get to the reds or close you must stop. And be rescued. All the lights can really tell you is when the pack is at about 95 percent empty.
THIS is what the little meter that Shirley sent is for. So when you get near the end, you can see that no single cell (group) is going to be empty before the rest. That would be bad...You would look at it when stopped, and see 8 voltages. The lowest one is the important one.
2.8V to 2.7V and thats as low as you want to go. 2.5V According to headway.
No damage till 2V. But that happens about 400 yards later...
It stays good, stays good, stays good, falls of a cliff!
shirley_hkg wrote: Your gauge will not tell you anything now , because there is no lead inside .
Set the low voltage alarm of the monitor at 2.8V .
Use it when you lose a green. When the alarm sounds, you should consider NOT going any further.
I can assure you of that one over discharge will ruin your pack. Yes, just once.
Burgerman wrote:That was the point!
i will try to get 30 miles one day and see how much i used up -
Users browsing this forum: emilevirus and 141 guests
