Postby woodygb » 06 Aug 2016, 11:55
Postby gcebiker » 06 Aug 2016, 13:17
Or the EJ MX, i think we are on the right track, the casing looks to be a match.
http://www.ebay.com/itm/Everest-Jenning ... 0674657590
Is this Dynamic software they are using ?
gcebiker
Postby gcebiker » 06 Aug 2016, 13:20
gcebiker
Postby peterik » 09 Aug 2016, 07:38
Where do I buy cable?
joystick
peterik
Postby peterik » 09 Aug 2016, 07:59
peterik
Postby woodygb » 09 Aug 2016, 13:57
No idea...sorry
Postby peterik » 09 Aug 2016, 13:58
peterik wrote:cable may be? electric wheelchair to RS232 male
To connect a programming RS232 module to power the joystick flashes and not a Wheelchair
peterik
Postby gcebiker » 09 Aug 2016, 14:05
http://www.ebay.com/itm/Everest-Jenning ... 0635212125
That is as close as i could find....and i DONT know what i am talking about, i have no idea about your chair, sorry.
gcebiker
Postby peterik » 16 Dec 2016, 09:23
eletrického my chair, I would need about one programmer kale where we find him:
http://kisss-by-meyra.de/myoIS/dokuweb/ ... 476181.pdf
peterik
Postby Burgerman » 21 Dec 2016, 15:55
Just found an old parallel port dongle for Dynamic. Will this still work with the latest stuff today?
I realise I will need some way of connecting it to a machine with no parallel port... Is there one? Is it this easy? What about connecting to the chair (DX2 for eg).
Postby woodygb » 21 Dec 2016, 16:03
Could you please post a pic .
Postby Burgerman » 21 Dec 2016, 16:33
Postby Burgerman » 21 Dec 2016, 16:34
Needs a clean!
Found in a box of old stuff. But from what I remember its an old OEM dongle.
Postby Burgerman » 21 Dec 2016, 16:57
Postby LROBBINS » 21 Dec 2016, 19:16
Even an old dongle will still work. You also will need the appropriate programming cable to either mate to the separate programming port on some controllers, or with an adapter, to the charger port on some others. It can be RS232 or, with another adapter, USB. Probably the easiest way to go is to find an old laptop with RS232 and Centronics ports. Used just for Dynamic software, even old, and crappy, Windows OS will be fine.
Postby Burgerman » 21 Dec 2016, 19:19
Maybe. But old laptops offend my sensibilities! I want to make it work from my current laptop or PC. If need be I can add a card with parallel port.
Postby gcebiker » 22 Dec 2016, 08:35
This will give you the output, USB to parallel https://www.jaycar.com.au/usb-to-parall ... e/p/XC4847
gcebiker
Postby gcebiker » 22 Dec 2016, 08:37
Oh...its just the key, you dont even need that any more ;)
gcebiker
Postby Burgerman » 12 Jan 2017, 17:53
Tell me what I need for the latest brushless Dynamic powerchair to get OEM level!
And or what is the latest Wizard version. And why don't I need a key?
Here: https://dynamiccontrols.com/en/download ... -downloads
What else do I need, and what connectors? To program this? http://www.invacare.co.uk/sites/uk/file ... 8b45b3.pdf
Postby woodygb » 12 Jan 2017, 18:06
The joystick appears to be a ACS2 ...
This pdf suggests you that need a DWIZ-ADAPT.
The XLR programming / charger socket is located at the front of the ACS2. To use this
socket with the HHP or the PC-Wizard programming cable, a DWIZ-ADAPT adapter
plug is needed.
I'll be happy to lend you one should you require it.
https://dynamiccontrols.com/en/download ... anual/file
Postby Burgerman » 12 Jan 2017, 19:46
No its REM550. https://dynamiccontrols.com/en/download ... guide/file
Thanks for the offer. But what about a dongle and permanent access? Do I need buy the kit from someone on this forum, who kindly offered?
Postby woodygb » 12 Jan 2017, 20:46
A dongle-less alternative exists.
I have the DWIZ-ADAPT ( Genuine ) ...
The DWIZ outputs a std serial signal.... So you should just need the addition of a cheap USB-SERIAL LEAD.
Postby Burgerman » 12 Jan 2017, 22:32
DWIZ - ADAPT
ORANGE DWIZ - ADAPT...
Whats the difference and where can I get one easily! :oops: Thanks!
Postby woodygb » 13 Jan 2017, 00:53
I haven't a clue what an ORANGE DWIZ-ADAPT is...?
The DWIZ-ADAPT simply converts the weird / Non standard signal that comes from the XLR of the pod to a normal serial output that can be easily read by almost any cheap USB-SERIAL cable.
So COMS can be easily sorted....
HOWEVER.
The STANDARD Dynamic Wizard program uses HASP encryption and looks for a Dongle .... if one isn't present it will not allow communication to take place and thus you cannot then program the controller/pod.
Postby Burgerman » 13 Jan 2017, 00:57
Fair enough. But where to acquire one. And maybe a programming lead?
Postby woodygb » 13 Jan 2017, 00:59
Scroll up .... I offered to lend you my DWIZ-ADAPT.... it's NEW and never been used.
Postby Burgerman » 13 Jan 2017, 01:02
Yes I know. And appreciate. But I want one! :P
Yes I know. And appreciate the offer. But I want one! :P
Postby woodygb » 13 Jan 2017, 01:06
It's very little use to me ...I bought it on a whim ... so £25 and it's yours.
I may perhaps in the future ask to borrow it ... yes?
Postby Burgerman » 13 Jan 2017, 02:29
Sold! Yes of course! Thank you! Paypal?
Could I buy a programming cable anywhere without poking wires in? Already ordered the right USB serial connector.
Users browsing this forum: emilevirus and 413 guests
