1. Any idea how this big variance in voltage within a group might have happened and how to I prevent it from happening again?
2. Is there anyway to 'save' the cells that didn't charge up?
If you look at the top row where there are 6 negative cells. Going from right to left, the voltages are .8v, 1.4v, 2v, 3.4v, 3.4v, 3.4v
- Output Voltage - as I understand the guidance above after about 1 hour of post charging this should be 3.6 volts for a good cell. What if it is less?
- Output Capacity - is the the total capacity of the cell i.e. 12000mAh for a fully charged cell or the capacity added during the specific charging
- Charge Level % - after about 1 hour post charging I believe for a good cell this should be 100 or close to it. Is this correct?
cdb0ewm wrote:Sorry didn't see expresso questioins.
It is a BM3 capacity pack. It's going in a modified Quickie P222 frame - so far it all fits
Users browsing this forum: emilevirus, shirley_hkg, wchl25 and 104 guests
