Brushless eBay!!! Bought.
Re: Brushless eBay!!! Bought.
Postby Vitolds » 31 Jan 2017, 22:12
+roboteq
Vitolds
Postby Burgerman » 31 Jan 2017, 22:20
Vitolds, see pm.
Postby Vitolds » 31 Jan 2017, 22:36
:lol:
Vitolds
Postby Vitolds » 31 Jan 2017, 22:37
Vitolds
Postby Vitolds » 31 Jan 2017, 22:44
1:10 = 500 PM
BIG WEIGHT :(
8kg + 6 Nema kg
Vitolds
Postby Vitolds » 31 Jan 2017, 22:46
Vitolds
Postby Burgerman » 01 Feb 2017, 00:00
But no good for powerchair.
Postby Vitolds » 01 Feb 2017, 00:08
Vitolds
Postby Vitolds » 01 Feb 2017, 00:12
only sport ;)
Vitolds
Postby shirley_hkg » 01 Feb 2017, 03:32
Uk ebay has quite some nice chairs . Looking forward to come across a nice TTplus Xplore . :D
Hay, you guys please keep an eye on it for me too . :x
Postby Burgerman » 01 Feb 2017, 10:00
There was one about 2k recently.
Postby Burgerman » 02 Feb 2017, 12:01
Now have a totally mint shiny REM 550.
https://dynamiccontrols.com/en/download ... sue-2/file
Postby hank » 02 Feb 2017, 13:26
8-) Turn up the volume :lol:
Have fun programming you new stuff.
Postby Burgerman » 02 Feb 2017, 14:46
Just spoke to a tech guy at Dynamic. He told be all DX-GB power modules are basically the same as long as they are all the 4 pin DX BUS connectors no matter what the extra designations or names used. Inc all the mk4, 5, 6i are all the same (just fancy invacare designations) but may have different firmware that limits some options in settings, and that they don't store a copy of the memory setting. Battery connectors, cable lengths, motor connectors vary by part numbers. The programmer sees them all as DX-GB.
All the motors are 3rd party, and now invacare only as a source, and they have just been significantly redesigned for a 40 percent torque increase over the 2nd versions. Called plus... Also improved efficiency. You cant buy brushless controllers from dynamic any more but they do make them soley for dynamic (unofficially) and thats also now the only source. And DX bus joystick can be programmed to work them from C versions and upwards. UK, EU, US all the same.
Postby hank » 02 Feb 2017, 14:53
Interesting read John.
Nice to know on what models will and wont program. 8-)
Postby Vitolds » 02 Feb 2017, 17:04
you can say what you will do with this invacare?
Vitolds
Postby Burgerman » 02 Feb 2017, 17:04
Shirley, can you get these cheaper too?
http://www.j-mart.biz/j-parts/index.php ... ts_id=3707
I need ONE wheel G-craft 8 x 5.5J plain and...
One x wheel G-Craft 8 x 4J plain.
Each wheel gives me a left and right half rim.
So making the brushless motor wheel rim 8 x 4.25 wide and 3.25 wide.
One for W I D E stretched 120/70 tyres, one for 110/80 on the xplore chair.
And with both motor/rim sealed should be OK tubeless.
Postby shirley_hkg » 03 Feb 2017, 00:35
Will try ..
Postby Burgerman » 03 Feb 2017, 00:49
Thanks!
Not symetrical... So will need 2 rims! :x
http://www.gm-moto.jp/item/mky-00121/
Maybe they have the flat ones no holes that I need.
Postby shirley_hkg » 03 Feb 2017, 03:40
No fruitful result .
3.5j for 8 inch / 4.5j for 10 inch . :cry:
I guess my mechanics can lathe one from a aluminum block , estimated £50 for one half .
Postby Burgerman » 03 Feb 2017, 04:30
The metal will cost 5x that!
Postby shirley_hkg » 03 Feb 2017, 05:24
No, it is cheap here , even 6061 grade .
Will get a close estimation , after the Luner NY holiday , if you are interested .
Postby Burgerman » 03 Feb 2017, 08:17
Sounds good! May as well have holes in the right places!
Postby shirley_hkg » 03 Feb 2017, 08:59
Alternately , cut this apart , and put an extra ring section to extend to your desired width . Weld them together , lathe the slot for rubber seal, and redo the finishing .
That may be even better and costs less .
This costs £12.00 a rim .
Wait till you received the 8” rims and confirm them fit for modification .
Postby Burgerman » 03 Feb 2017, 09:45
It wont. The center well, too deep... No room for bolts. Unless I drill 5 new holes in the rotor...
Postby Burgerman » 03 Feb 2017, 12:35
My motors arrived. They look almost new. Barely even dusty. Better than the pictures!
And my refurb (absolutely brand new if you ask me!) REM 550 joystick is here already.
Power module also here. Cables quite short but easy to make an extended one if needed. Also looks like new. Do people actually use these chairs?
And I won this http://www.ebay.co.uk/itm/Invacare-ACS- ... fresh=true
Because I need a spare and because I am going to fit one of woodys RC interfaces so I can RC my brushless invacare chairs... Can just leave a spare buss cable where its easy to connect if when needed.
And I need a couple of wheel rim halfs for the brushless to measure and test...
Postby shirley_hkg » 04 Feb 2017, 04:04
After setting them up , REMEMBER to calibrate motors first , before running them , even unloaded . :o
Postby shirley_hkg » 04 Feb 2017, 04:25
I'd have thrown in a pair , if I had known it earlier .
Ask him . He always has stock .
http://m.ebay.com/itm/Invacare-Control- ... Ciid%253A7
Postby Burgerman » 04 Feb 2017, 11:31
72 dollars shipping alone for a power module! Buying in the US also always means customs rip off charges and vat on top...
Can you possibly post me a couple with cheap Chinese postal service?
Postby shirley_hkg » 04 Feb 2017, 11:36
Will find the pair that I set aside . ;)
Users browsing this forum: LROBBINS, shirley_hkg and 388 guests
