Burgerman wrote:So... Where can I get a 21pin connector for the DX CLAM module so I can see if my old corroded one still functions!
I have a query...
I have 4 levels.
Lite (dealer)
Standard (Enhanced Dealer)
Advanced (OEM) which leaves a good few technical things greyed out...
And Service. I expected "write" as shown in the manual which only allows you to write a fixed profile and not editable. But Service appears instead, and seems to allow access to almost everything including stuff like below, giving us ample opportunity to really stuff things up!!!IF it allows me to write this to a controller. It does let me save to desktop. Seems to be a higher level than OEM unless I am seeing things.
woodygb wrote:It would seem that a Dongle Emulator is being used.
http://testprotect.com/appendix/Mk_manual
If you read thru the manual you can see the registration choices that have made by the Dongle Emulator to trick the Wizard program..
E.G."DongleType"=dword:00000001
So ... "DongleType"=dword:0000000x - тип ключа
1 - HASP (3,4,HL,SRM)... which is what Dynamic uses.
"Type"=dword:000000xx - модель
0A - HASP4 M1 (deafult)
"Memory"=dword:00000001 - размер памяти
00000001 - 0x80
ETC...
Micky1964 wrote:Sorry but I am very new to this. Could someone please tell me where I can get a copy of the PGDT oem programmer software. Thanks in advance.
TestTech wrote:Hey Guys.. I'm a newbie here, and been reading non stop for the past few days.. and trying to find the working version of the PG OEM programmer.zip
Can some one help me out please ? I've got a Pride PWC with a VSI controller that I want to fiddle with.. I'm a Electronics Techy, so the cable won't be an issue, just need the SW..
Thanks in advance. TT..
woodygb wrote:http://www.wheelchairdriver.com/board/viewtopic.php?f=2&t=329&start=0
woodygb wrote:The PGDT cables.... other than R-net ... are easy to make ...or I can supply you one.
Users browsing this forum: Juggler258, LROBBINS and 551 guests
