Burgerman wrote:Surface postage= cheaper. And the rims only, and 3.50j x 8. Then be ready to spend 100 on 120/70-8 tubeless tyres!
Scooterman wrote:120 must be 120mm wide where? Across the widest point when inflated?
70 must be 70mm deep wall?
shirley_hkg wrote:Scooterman wrote:
I'm at your service . It is around £23.00 a wheel with 3.50-8 tyre .
With BM's measurement , I can make & ship with those spacers too .
I did read the guide but still don't fully understand? I believe 3.50" the width of tread and 8" is the rim diameter? . Even the spacers are confusing me, but perhaps I'll understand more when the chair arrives I take one of the wheels off.
Burgerman wrote:All wheels are 8 diameter.
3 different WHEEL widths. You need 3.5.
Tyres are all different. To fit a 3.5 wide tyre, you need a 120/70-8 tubeless. Those dont come from china. They are bought locally and very expensive.
Burgerman wrote:The caster rims are 4 x 1.75 and rear ones are 8 x 1.75 on both chairs.
biscuit wrote:scooterman, you're always asking what I want to know so every answer time you get an answer, that's two people at least that have been informed.and you have almost the same chair as me.
shirley-hkg in a couple of months I'm going to want tyres and spacers for my salsa r2 as well, not immediately though, as I am broke plus have not done anything to my chair, so my battery takes up the space currently.
shirley_hkg wrote: I can get 3.50-8 tyre only .
It is tubeless and it is the only thread pattern available here . Valve included .
Burgerman wrote:And now my lazer cut wheel adapter parts are here. 3 days! And now to mark/drill...
On the left.
Remember this:To fit those rims to a salsa, you need:
Spacer ring:
Inside diameter 41.5
Outside diameter 110.0
Cover plate 2 parts.
The chair arrives on Tuesday. After I've had it a few days tried it, and decided I like it and want to keep it.
Would you be able to sort me out with everything I need to swap all four wheels for nicer wheels with black pneumatic tyres, valves, spacers, bolts and anything else I might need?
Is the black tyre the same as this one? https://www.mytyres.co.uk/cgi-bin/rshop.pl?dsco=110&cart_id=10004252.110.64590&Breite=120&Quer=70&Felge=8&Speed=&kategorie=&ranzahl=1&tyre_for=&x_tyre_for=&F_F=&m_s=1&rsmFahrzeugart=MO&details=Ordern&typ=R-255800Burgerman wrote:Compared
Burgerman wrote:Yes. Although the image incorrectly shows a narrower 3.50 one. But DURO are better. I have both.
Burgerman wrote:You are not looking for 3.50 x 8!!!
The ones you linked to, k75, are OK too.:
120/70 8 HERE https://www.shirebikes.co.uk/collection ... eless-tyre BUT out of stock when I ordered. I had to order in germany.
They do them in 3.50 x 8 too. And that IS the wrong size!Funnily enough when I googled duro 3.50 x 8 I got hit on that site and them tyres but discounted them as being the wrong ones
Burgerman wrote:3.50 is inches. They are 3.5 inches tall sidewall, 3.5 inches wide.
120 is in mm... So 120mm wide. Or about 5 inches.
But the /70 is a percentage. So its 70% of that 120 tall. Thats the same height as the ones above. So wider, not taller!
shirley_hkg wrote: Beware of the chair will be 27.75'' wide , if 120/70-8 tyres deployed .![]()
Burgerman wrote:https://www.shirebikes.co.uk/collections/tyres-tubes/products/120-70-x-8-heidenau-k75-road-tyre
correct...
https://www.sip-scootershop.com/en/prod ... +_80204003
wrong!
https://japan.webike.net/products/2078096.html
correct...
https://webshop.lucdebondt.be/winkel/bu ... -3-50-8-2/
Wrong!
What would be the next width size down from 120mm?
Burgerman might be best able to answer the following question. Does the Salsa need wheel spacers to enable the fitting of all aftermarket nicer wheels and tyre combos. For example if I was to fit 4" wide tyres could you get away with not having spacers? Just curious, it would give me something else to consider...
Burgerman wrote:The chair arrives on Tuesday. After I've had it a few days tried it, and decided I like it and want to keep it.
As it arrives, you wont like it and will not want it as its unusable. And it wont work properly. They are all like that.
Users browsing this forum: slomobile and 103 guests
