PSU - Info
Re: PSU - Info
Postby shirley_hkg » 07 Mar 2018, 04:01
OK , I suppose you'll take new old stock , not used items .
PSU + postage HK$1,200.00
PSU + CASE + postage @ HK$1,430.00
Paypal & pm me your Shipping address .
Re: PSU - Info
Postby steves1977uk » 08 Mar 2018, 10:54
Just sent you a PM Shirley :thumbup:
Re: PSU - Info
Postby shirley_hkg » 12 Mar 2018, 03:17
Gnomatic hasn't responded yet . Wait him another week and go ..
Re: PSU - Info
Postby Gnomatic » 13 Mar 2018, 16:14
Sorry shirley, been busy and havent kept up here.
I will send you PM with shipping and PayPal info.
Re: PSU - Info
Postby Gnomatic » 14 Mar 2018, 03:10
Thank you shirley, payment sent! :thumbup: :dirtbike :biker
Re: PSU - Info
Postby steves1977uk » 14 Mar 2018, 12:03
Payment sent Shirley. :thumbup:
Re: PSU - Info
Postby shirley_hkg » 14 Mar 2018, 15:11
Six hours after checkout , they are coming to my way . cheers
Re: PSU - Info
Postby Gnomatic » 16 Mar 2018, 04:56
Looking forward to it, shirley! :thumbup:
Re: PSU - Info
Postby shirley_hkg » 17 Mar 2018, 10:31
Foster home .
Re: PSU - Info
Postby steves1977uk » 17 Mar 2018, 11:37
Can't wait! :clap: :dance
Re: PSU - Info
Postby Burgerman » 17 Mar 2018, 12:05
You wont have much choice. Takes ages! Slo boat from china! :joint
Re: PSU - Info
Postby shirley_hkg » 17 Mar 2018, 13:56
Delivery in 2 or 3 days via Speedpost , postage doubled . :wave:
Allow me to test it , before shipping out . cheers
Re: PSU - Info
Postby Gnomatic » 17 Mar 2018, 15:54
Looking good. :)
Re: PSU - Info
Postby shirley_hkg » 24 Mar 2018, 11:11
Parcels are out today .
Re: PSU - Info
Postby Burgerman » 24 Mar 2018, 11:16
Excellent! Thanks for all your hard work. Now we wait. :worship
Re: PSU - Info
Postby Gnomatic » 24 Mar 2018, 16:42
Thanks shirley!
Re: PSU - Info
Postby Burgerman » 24 Mar 2018, 18:47
And then out with the soldering iron. And into the new case with anderson connectors and so on.
So it can charge chairs directly or via the PL8 or whatever.
Re: PSU - Info
Postby steves1977uk » 24 Mar 2018, 22:18
Thanks Shirley :thumbup: :clap :dance
Re: PSU - Info
Postby Burgerman » 24 Mar 2018, 22:22
We will ned a build thread!
Re: PSU - Info
Postby shirley_hkg » 25 Mar 2018, 05:37
No , you don't need one.
You guys opted the one that they are modified already , @ a beer.
Burgerman wrote:We will ned a build thread!
Re: PSU - Info
Postby Burgerman » 25 Mar 2018, 08:37
I meant for swapping case, anderson, fuses, etc.
Re: PSU - Info
Postby shirley_hkg » 19 Apr 2018, 02:57
Try it on a pair of old MK Gel.
CV @28.2V ,for 9hrs . Current seems won't sag any further .
Re: PSU - Info
Postby Burgerman » 19 Apr 2018, 09:16
Because they are old...
With older batteries you need to lower charge voltage. The correct voltage at room temperature is 13.8 up to a max of 14.1V. But old batteries are not efficient and warm up as you charge so voltage must be lower. And the older they are the higher this current will be.
To desulfate old batteries as much as possible leave on a small 200mA limit with 15v max for around 3 days. But dont expect miracles!
Re: PSU - Info
Postby snaker » 08 Nov 2018, 02:33
I bought this 30V PSU. It looks sturdy and high quality.
https://item.taobao.com/item.htm?id=19995041970
I have some questions about this PSU:
1. I see 4 terminals +S, -S, SHARE BUS, ON/OFF in the center. What are they and what do they serve for? If it is unused, should I insulate them or leave them alone.
2. I worry about the non-insulated AC input terminals. Is there any solution to insulate them?
Re: PSU - Info
Postby shirley_hkg » 08 Nov 2018, 08:45
Hot Glue as insulation . drunk2
Re: PSU - Info
Postby snaker » 08 Nov 2018, 10:53
It seems this PSU was built for Military use. It is truly bulletproof :cussing
Re: PSU - Info
Postby Burgerman » 08 Nov 2018, 11:34
Unless charging at max power, I always choose 24V so that the charger is always in boost mode and doesn't need to swap from buck to boost at any time. But failing that setting it at anything under 30v should be ok.
Re: PSU - Info
Postby Burgerman » 08 Nov 2018, 11:40
Mine do. Yours dont because they are sulfated and old. So set termination or transition to float to occur at .5A instead of .2.
Or set volts to 28.0 instead. Or try to charge at CV for around 8 hours anyway, it might remove some of the sulfates. But watch out as the current can begin to increase. And then the battery gets warmer. Then it draws more Amps... Gets ever more warm, and melts...
Re: PSU - Info
Postby shirley_hkg » 08 Nov 2018, 13:07
Roger that .
Re: PSU - Info
Postby snaker » 11 Nov 2018, 10:45
Burgerman wrote:Unless charging at max power, I always choose 24V so that the charger is always in boost mode and doesn't need to swap from buck to boost at any time.
Is the boost job easier and more efficient to PL8 than buck? If the purpose is only to charge a 24v lifepo4 pack at a medium current what input voltage is the best?
Users browsing this forum: acid_coke, F3Head, Gregrb, iansp, JMGarage, LROBBINS and 120 guests
