Postby Burgerman » 22 Jun 2018, 16:43
What is: display roCP
Postby Furio » 22 Jun 2018, 17:27
The following are the screen shots.
Furio
Postby Furio » 22 Jun 2018, 17:29
More.
Furio
Postby Furio » 22 Jun 2018, 17:31
Last.Not in order.
Furio
Postby Furio » 22 Jun 2018, 17:46
In OFF position the display shows: -8.1 oFF
In ON position it is: -4.7 -8.0
Now roCP does not appear on display.
furio
Furio
Postby Burgerman » 22 Jun 2018, 17:54
Interesting! You may have messed with its calibration? And have complicated it all by turning on/off lots of features and have many a numbered settings memory!
Postby steves1977uk » 22 Jun 2018, 18:11
Postby Burgerman » 22 Jun 2018, 18:45
In a week, when I get off this damned bed again, I will photograph my correct settings so you can just copy.And as long as you didnt choose to recalibrate, then all will work normally.
Postby martin007 » 22 Jun 2018, 18:47
Are you sick?
Postby Burgerman » 22 Jun 2018, 19:12
Pressure sore ischeal tuberosity...
Postby shirley_hkg » 23 Jun 2018, 03:22
Steve is right . You might set the over-volt protection too low and trigger the output stopped .
Go to menu 8 and see what value is it.
I advise 1.5V---2.5V.
Change it and return to menu 5 to save the change .
Postby Furio » 23 Jun 2018, 05:55
Menu 8 V and A was at 1.0 . :oops: I moved it up to 1.5 saved,and tested.No change in out put voltage and display. So then increased to 2.0, and then to 3.0 but to no avail. The output voltage remains the same; also the display. :cussing
Another thing I left mentioning yesterday, while tinkering with the settings(only from the panel), the fans revved up suddenly and the left side (side with the sticker) was quite hot without any load connected. :o :roll: Immediately I switched off the charger. And now after the menu 8 increased to 2.0 - 2.5, the left side was slightly warm. :?
Furio.
Furio
Postby shirley_hkg » 23 Jun 2018, 08:19
Go to menu 7 to restore to factory preset
Postby Furio » 23 Jun 2018, 09:20
Some other observations:
Menu #2 setting: 19V Menu#8 setting: 0.1V Output Voltage: roVP
Menu #2 setting: 30v Menu#8 setting: 0.1V Output Voltage: 2.4V
Menu #2 setting: 30V Menu#8 setting: 1.5V Output Voltage: 5.0V
Menu #2 setting: 30V Menu#8 setting: 3.0V Output Voltage: 5.0V
Menu #2 setting: 60V Menu#8 setting: 3.0V Output Voltage: 10.5V
I will do the factory reset and see. :worship
Furio.
Furio
Postby shirley_hkg » 23 Jun 2018, 10:02
Then redo chapter 7 auto calibration .
Postby Burgerman » 23 Jun 2018, 11:54
I see a mushroom cloud over india :clap
When he was a child I suspect he took everything apart and broke it... :shh:
Postby Furio » 23 Jun 2018, 13:42
BM. Now the mushroom cloud is blown away :dance drunk2 .Actually it was monsoon cloud.:thumbup: :joint
Only the auto calibration is remaining :geek:
shirley_hkg .Thanks.
Furio.
Furio
Postby Burgerman » 23 Jun 2018, 14:57
Dont burn your chickens until your bridges have hatched. Or something... :fencing
Or was it, dont count your bridges until your chickens are burned? czy
Postby Gnomatic » 23 Jun 2018, 17:04
Finally got around to cutting a notch out of the back plate of the fancy case to allow room for the anderson to be fitted on the back of the charger. Used a small rotary tool and a hacksaw.. Cleaned it up a bit with an old file I had laying around. It looked great, a very clean cut notch.
One problem - the notch was a tad shallow for the anderson to fit. :fencing So I had to take the old file and file away to deepen the notch until the anderson fit, which it now does. Unfortunately now looks pretty jenky, not all nice clean and even like when I finished the initial cut. Oh well, thats just cosmetic. And I won't be looking at the rear of it often. Bit it bothers me at the moment when I see it.
On another note, I'm 99% sure a 25mm thick will not fit in the front of the fancy case. There is plenty of room for a 25mm thick fan in the rear of the case however. I'll be adding that. Also replaced that thick mesh on the front of the case with a chunk of speaker grill. The holes are too big for it act much as a dust filter, but it will keep bigger particles out and allows air to actually flow.
Postby Burgerman » 23 Jun 2018, 17:16
And allow sound out. That horidly restrictive stuff it came with was likely used to quieten it. But better to use a quiet fan. Or even a stopped fan since the air flows well with just the rear one especially if you fit a thicker one without that grill. Remember that the two heat sinks are now firmly bolted to the 3mm allow case sides. So the case becomes a heat sink too. If you add two bits of that grey packing polyurethane foam 25mm x 25mm x 90mm to the case top and bottom, you also force the all the air to flow through the heat sink fins.
P.S. I measured two andersons plugged together, and added .5mm to it both ways. And scribed it onto the metal before cutting. I have done this before... And have done as you did in the past. :cussing
download/file.php?id=8333&mode=view
download/file.php?id=8334&mode=view
Postby Furio » 24 Jun 2018, 08:44
Well, it is not as expected. The charger refuses to enter auto calibration mode. banghead :cussing
The output voltage can be adjusted as desired but :argument The moment an ammeter is connected,with menu#4 set at 9A, the voltage sags to zero and current at 2.5A. So banghead banghead
Am I looking at a hardware...........? hanged
After charger reset, the default display is 2.62V, 0.06A
Menu#1 01V 715, Menu#2 80.0V, Menu#3 01 424, Menu#4 9.0A, Menu#5,6,7 default, Menu#8 -- --,Menu#9 00^^000,
Menu#A ^^00000, #B , #C ver.3.17
Is menu#2 80.0V OK? czy . ^ means ON.
Furio.
Furio
Postby Burgerman » 24 Jun 2018, 10:46
wait for shirley. One of the settings is 60 or 120V and 25 or 50A.
He seems to understand all this as he mods them.
Postby shirley_hkg » 24 Jun 2018, 11:38
The mod guy has locked the menu , that also prevents user to use auto-cal again. Because it will automatically clear everything and back to factory preset.
Click Steve's page and see what menu E is about.
Change the value @ADDRESS 99 back to ZERO , and save it . (look if it is 88 currently).
Turn off PSU . Press and hold 15 sec till you see a white 0 , and you are into aoto-cal again.
Postby shirley_hkg » 24 Jun 2018, 11:55
:dance
:clap
:dance
Postby shirley_hkg » 24 Jun 2018, 12:01
John, find you 2 long lost friends. drunk2
Address 73 , 74 , would make it a competent auto 3-stages charger now. :clap :dance
Postby Burgerman » 24 Jun 2018, 12:02
Its god day today. I am not religous. I find it rediculous. If I were you I would pray anyway! It might help! :worship
Postby Burgerman » 24 Jun 2018, 18:04
Do not understand.
Its already a 3 stage charger, user sets the voltages. And termination current. Works very well. If you set transition from CV to float to 0.1A or 0.2A.
You cant do that automatically, as you need 29.4V CV and 27.2V float on Odyssey, but 28.2V CV and 27.0V for gel. It cant do both automatically? One or the other.
Postby Burgerman » 24 Jun 2018, 18:20
If it sees a direct short, such as an ammeter, it may turn off power to protect itself. Many supplies do that.
Postby shirley_hkg » 25 Jun 2018, 02:06
https://translate.googleusercontent.com ... YSUxnym3fw
:fencing
The residual current for switching to float , and the float voltage , are changed back to preset values , WHENEVER THE BULK VALUES ARE ALTERED .
By entering user's values here, we can lock the float A&V to a sensible rate that we think appropriate .
No bother to re-write them every time ,
assuming bulk charge rate is in proportion to the C of the battery .
givebeer :clap :dance drunk2
Postby Furio » 25 Jun 2018, 06:03
shirley_hkg wrote:The mod guy has locked the menu , that also prevents user to use auto-cal again. Because it will automatically clear everything and back to factory preset.
A doubt. Both menu E and F have identical parameters. Do we have to change ADDESS 99 in both menus?
Furio.
Furio
Users browsing this forum: duke1, emilevirus, LROBBINS, Superchunk and 238 guests
